Rob Geebivi
Hi @Davy Wentzler ,
I've had this apparent issue for a couple months, but I haven't gotten around to asking you until now... It happened soon after I updated to Android 9 from Android 8 on my G7, which was around December. (I did not keep close attention as to if this was an issue brought about by Android 9, or if it was just a coincidence with other UAPP changes... sorry. I'd be happy to test multiple system and / or UAPP versions if that'd be helpful.) FYI: I'm not using an external DAC; I'm just using what's built-in to my G7 and certified HiRes earbuds over the 3.5mm jack.
When playing 352/24 FLAC files loaded on my phone storage and SD card, in the phone settings app, turning the "Hi-Fi Quad DAC" to On decreases the audio quality (noticeable compression, digital filters change the sound, etc.). In other words, when the system slider is set to "On," listening bit-perfectly does not appear possible, even though enabled in UAPP. I've ignored this for a while, because I can get around Android's de-facto audio haze machine by turning the system "Hi-Fi Quad DAC" off (which I find quite ironic). Only catch is that I have to deal with the coarser volume control from the system when in this mode, rather than the "Hi-Fi" volume slider numbered 0-75, which is starting to get annoying now after a few months... Hence the message now
I never had to do this back in Aug / Sep / Oct when I bought UAPP with HiRes FLACs. The "Digital filters" and other modifications never did anything to the sound. In fact, this is still how it operates with 5.6Mhz DSD files loaded on my phone. When playing DSD files, changing the "digital filter" in Android settings does nothing to the sound. Interestingly, the "Hi-Fi Quad DAC" must be on in Android system settings order for UAPP to begin playing any DSD files. Once it does, it goes to my earbuds untouched. But, if I switch to a track in 352/24 FLAC in UAPP, then I have to go back to settings to turn off the haze (and my nicer volume control
The way the system plays DSD files compared to PCM files is a mystery to me, but I'd love to learn how / why the system reacts so differently to these kind of files. My curious brain will take as many details as you're willing to hand out
I have a second issue with the audio on my G7, but I think it might be faulty hardware... So if you don't have any thoughts as to why this would be occurring, no need to respond. That said, I'd love to know if there's anything I can do software-wise to possibly fix this too
If I ever play any music--except DSD files, which are immune from any system adjustments still--with the DTS:X 3D Surround on (in Android system settings), it sounds like nonstop static, jitters, and stuttering (and the music sounds like it's going too slow). I've just stopped using it altogether due to these issues, but it was kinda fun to play around with some of my redbook FLACs a while back as it added a decent effect without killing the redbook quality. (This wasn't possible through UAPP the first couple months, as Android couldn't adjust the audio stream, but there was a period of 2-3 weeks right after the Hi-Fi DAC switch issue started before this issue started creating static.) It's not important to me if DTS:X ever gets fixed or not, but I figured it was worth mentioning.
