Im going to be getting a set soon, that will be sent of for remolding. Very excited!
Unique Melody Miracle Review & Impressions Thread
- Thread starter FYJX
Ordering my CIEM in a months time! Been working and saving loads for this moment. Definitely worth the wait after trying the demos.
Only concern is should I use their cables for the time being before the next upgrade? Or should get a Chris cables. =/
iamthem
- Feb 24, 2012
According to MaoDi's review the Miracle uses two Mage high drivers and a different Mid driver. From what I read the Mage uses TWFK for its high and mid driver, which implies in the Miracle there are two TWFK's and two (unknown?) midrange drivers. But that wouldn't make sense as TWFK are dual mid/high drivers so the Miracle would be a 8 driver iem with four high drivers, two mid drivers and two bass drivers. Could anyone shed light on this?
UniqueMelodyAus
Member of the Trade: Unique Melody Australia
- Nov 17, 2010
Mage - TWFK 1 mid 1 high
Miracle - TWFK - both highs.
There are many different types of TWFK. Some can be tuned for full range, some for mids only or some for highs only or some for one high and one mid etc etc etc.
Kuray
- Jul 24, 2012
How did you send your impressions to China. It tooks more than $100 for shipping.
Thanks
Thanks
psygeist
- Aug 4, 2011
Sent my impressions to UM lab in China on Friday. Now the wait begins.
psygeist
- Aug 4, 2011
Is it a dual bore version ?
Where can I get spare cable similar to stock ones but with different color for Miracle ?
psygeist
- Aug 4, 2011
Anybody here ?
Saraugie
Formerly known as Saraguie
I would be using these with a iPod, no amp or DAC.
A good many of the songs are so-so quality. Would the Miracle handle the not so good recordings well?
I've read that there are IEMs like the FitEar 334 for instance, that make the not so good recordings sound pretty good.
3nenbgumi
- May 10, 2012
Can anybody who is in possession of both the UM Miracle and the ACS - T1 Live! do a brief comparison between the two? I have rounded my choices of CIEMs down to those two due to price and availability, but for the moment I'm a bit biased towards the ACS - T1 Live! due to shorter turnover time
Thanks a bunch.
Thanks a bunch.
I strongly advise you not to purchase the miracles if it is for low quality listening... the sound signature is a bit U shaped with a slight bump in the bass region, but no point buying such an expansive device if your files are lower than 320.
Cheers.
Cheers.
3nenbgumi
- May 10, 2012
Thanks mate, but are you sure about that, because that sounds a bit contradictory to what I have heard about the Miracle sound characteristics? And to attend to your worries, I'm using a Studio V filled mostly with FLAC and WAV files, so that's hardly any concern.
Still waiting for responses.
Cheers.
Saraugie
It is a big investment and since custom's if they do not work, it will be hard to recoup the $$ spent if I sold them.
I have about 6000 songs in iTunes of which 75% are Rock/Blues, 10% R&B, the rest varied. I use a iPod and really do not want to use an amp but would if it made a substantial difference. I checked the info of a random group of songs and they are MP3 and Sample rate is 44,100. Isolation is very important and they need to not stick out of my ear too much.
I bought and am going to return Westone W4Rs because the sound is to anemic for me. I thought I would buy a amp which has bass and treble adjustments and EQ the sound. Wrote a former Head-FIer member who produces good quality portable amps and he said "I never advise buying an amp to fix the sound"
Which leads me to where I started.......which IEM to buy? After reading Joker's review of the Miracle I thought it would fit the bill.
Whatcha all think?
Whatcha all think?
Owning the miracles myself and using them with the fostex hp p1, yep, I'm pretty positive about their sound signature. Anyway, I don't think you'll be disappointed by them. And their soundstage is also very very very good for a ciem.
psygeist
- Aug 4, 2011
I will be getting mine by the end of week.
