Inear
- Nov 17, 2010
Bought the monster tips for 9 bucks on amazon lighting deals, lets see how these are..
yea i got like literally minutes ago, theyre pretty comfortable to me, but any in ear basically fits me, but yea the packaging was laughably bad!
Just got mine. First impression....they're uncomfortable. I've tried all the tips. The comply tips are the only ones that will really even go in, lol (even with the ear lobe pull method).
They sound fantastic though. It looks like I may need to pay to have them reshelled. Are there any Shure Olive-esque foamies that will fit, that I can try first?
(I got the eco packaging. Let me just say that it's crap. The box was pretty beat, but luckily the IEM's were fine.)
Like your box was beat up? I received several pairs, and the packaging on all of them have been in perfect condition. The packaging isn't as nice as the ones that came with the Shure SE535, but it's on par with Westone's packaging. lol.
The front of the box got squished a bit, with my instruction manual getting bent a bit inside the black box. The metal box was also a bit loose, since all that is holding it is a piece of thin cardboard. The IEM compartment (if you can call it that) was untouched thankfully, but it just as easily could have been damaged.
I'd rather have my product protected than have an "Eco friendly" box. That's just me personally. They could have completely alleviated the issue by putting the IEM's inside the protective case, and sticking the soft tips outside of it. Why do the tips need protection?
actually after wearing them for the past hour, i definitely notice these in my ear more than i have with any other IEM. I couldn't keep them in my ear any longer and had to take them out, i can usually have headphones in my ears for the whole day as i go from class to class, but with these i don't think i can. hmmmmmmm....
I think the pressure in the housing might have something to do with it. Try the comply foams that come with them, they solved any problems I had
Both left and right? I just got them...I highly doubt there are hair in both
I can keep my Ety's with Shure Olive's in my ears forever without discomfort. I think it has everything to do with how enormous the bore is on the TF10's. Compared to any other IEM I've ever tried, it's huge. (With the exception of a cheap pair of Skull candy's which had bores almost as big as my ear canal, without the tip.
The $100 or so to reshell is going to be money well spent.
well I can keep my cc51s in my ear for the hole day and it has a way bigger nozzle so it has to be something that I'm doing wrong
You're wearing it over the ear right? Take time to adjust the memory wire to suit you best. You don't want them hanging.
