Ultimate Ears Triple Fi 10 Thread
Jun 11, 2009 at 11:17 PM Post #2,116 of 9,690
So...no-one on this thread knows what
is all about?
I'll have to ask around.
Jun 12, 2009 at 9:14 PM Post #2,117 of 9,690
guys my tpf10's left channel low frequency driver seems to have died, is there any way to repair them? I cannot hear any bass from the left side, but the right is ok, i tried interchanging the cables to see if the problem is with them but still the same earphone channel has no bass. please help
Jun 12, 2009 at 10:07 PM Post #2,118 of 9,690
Sounds like an RMA job. Driver death?
Are they still in warranty?
Jun 13, 2009 at 11:54 AM Post #2,125 of 9,690
Good to hear it is now working - it may well have got moisture in it. I remember a similar thing happening to one of my IEMs (don't recall which one) a long time ago. Somehow I'd managed to get a bit of water on the housing, must've got down the nozzle & just muffled, reduced the sound output. Next day, bingo.
Jun 27, 2009 at 4:18 PM Post #2,126 of 9,690
hi, I am about to buy UE triple fi or westone 3, and triple fi seems having gigantic size. am I wrong? (I dont have big ears.)
I looked the images in earphonesolutions, but just could only see triple fi in the ears. can you compare these two iems according to their sizes? thanks
Jun 27, 2009 at 10:21 PM Post #2,128 of 9,690
rebetico, I should have W3 in a couple of days. I'll post how they measure up sizewise...and, yes, Triple Fi have quite a large housing but don't let that put you off. The 'bulb' in the housing does not go into your ear, lol! And you can wear them two ways: stock or flipped. But we can cover that once a size comparison is done...what do you need? Length, width, bore size? The bore size (of the sound tube, for want of a more correct term) is pretty large on Triple Fi but with the smallest tips, fine. If of course you're one of the many lucky ones who don't have an issue with fit...
Jun 27, 2009 at 11:13 PM Post #2,129 of 9,690
I also have small ears and don't have a problem with the TF10.
Jun 28, 2009 at 9:00 AM Post #2,130 of 9,690
I've owned TF10 for a while, and now had a problem about its cable. The connector (near the phones) are quite loosed like when I put them on and walk, the cable is detached from the phone quite often.
How I can fix it? aftermarket cable? or I need to send them to UE to fix it?
