jaw2ek
- Apr 11, 2007
Just found this. Very nice!
Unfortunately, its also a wishlist of extraordainary proportions!
Originally Posted by playingwithfire /img/forum/go_quote.gif average_joe, I may have missed it but what didn't you like about the UM3X? Maybe I am just getting used to them now but right now the soundstage doesn't sound too bad, the frequency is pretty flat besides a bump in the vocal range(not as forward as the W2 though) as well as having very good texture, cymbals and guitars both sounds realistic. I was just wondering what your gripe with it was...? Also, while we are at it, I'm getting the Monster Turbine Copper soon, what tips would you suggest? My problem with the gold was that they don't go in deep enough(I have shallow ear canal, which does fine with most phones) and are prone to falling out or losing seal. Thanks |
Originally Posted by ben4345 /img/forum/go_quote.gif Makes me want to try out the PL50's |
Originally Posted by ben4345 /img/forum/go_quote.gif Portland, Or 32 Ohm Audio |
Originally Posted by dongringo /img/forum/go_quote.gif I also live in Portland and bought my GR8s at 32 Ohm. I spent several hours one day trying almost all the IEMs they had and found the GR8 to be my favorite out of them all, though totally unexpected. Personally, I wouldn't oppose the top tier status of any of them after only listening to them for less than an hour in store. It's really not a fair thing to do without having owned them. There are some that I didn't like either in the store, but I'm not going to put my name on the Oppose list due to not having sufficient time with them. The GR8s took some time to open up and after a couple weeks they completely blew my mind like the demo pair did in the store. For some reason, people who haven't owned them keep bashing them here and because of that they are, unfortunately, under appreciated. The bass, mids and treble are very well balanced actually so I would classify them as transparent. And they aren't at all fatiguing like Grado headphones. The soundstage/imaging is also very good. I'm always amazed listening to old Porcupine Tree when everything is way outside my head. Sometimes, I think they might be actually too revealing though. For instance, I can actually hear the sound of a piano string vibrating, but is this really a problem? It's an amazing accomplishment for an IEM is what it really is. They sound so smooth that sometimes I can and do listen to them all day long. I will say though that just like top tier headphones, one should take care to pair them well with the right portable amp. For example, to my ears they sound much better with my ibasso T3 than my D4 which is twice the price. The bass is much more pronounced with the T3 for some reason, more in balance with the highs and mids. With the D4 they are less transparent. So pairing is important. All this being said, IMHO the GR8 is definitely top tier. I really wish more people would buy and try them like they do other gear, because I'm sure the popular opinion of them would be completely different. P.S. I used my own rig in store listening to the same 2 excellent recordings in order to do the best test possible and ended up walking out with the last IEMs I thought I would. |
Originally Posted by Kunlun /img/forum/go_quote.gif Sounds fun. What else did you try? |
Originally Posted by dongringo /img/forum/go_quote.gif From what I can remember, W1, W3, IE7, IE8, PK3, iGi, some Monsters can't remember which, Ortofon can't remember which, REO, and some others can't remember lol. It's been a few months. I'm still very happy with the GR8 purchase. I kept going back to them. They were definitley stand outs. |
Originally Posted by KLS /img/forum/go_quote.gif There is only one for Ortofon currently, the e-Q7 |
Originally Posted by playingwithfire /img/forum/go_quote.gif Also, while we are at it, I'm getting the Monster Turbine Copper soon, what tips would you suggest? My problem with the gold was that they don't go in deep enough(I have shallow ear canal, which does fine with most phones) and are prone to falling out or losing seal. Thanks |
Originally Posted by cn11 /img/forum/go_quote.gif @joe- The MD's should be top of the heap if you're going by the comments of those supporters you've noted. They've both said the MD's sound noticeably better than the other two. |
Originally Posted by chinesekiwi /img/forum/go_quote.gif Easily the best imaging in it's price range. Easily. I've listened to very high-end speakers (easily into the thousands of dollars) and the HD800 so I know a little bit about imaging It's not even close to those but neither is the pricetag |
Originally Posted by JeFFz /img/forum/go_quote.gif guess you could put me on the opposing side of the tf10. The more i listen to it, the more i can't justify that its as good as other iems. Which pushed me into buying the coppers |
The Copper was a female dog to get good positioning |
