claud W
To transmit to speaker, do I just cut Bluetooth on?
@Joe Bloggs Could Hiby make the R3 Pro firmware open source?
Open sourcing the firmware would be beneficial for everyone.
Just as the open source community has various licenses requiring any code utilizing them also be open source, there are equivalent (more) licenses on the closed source front requiring any code utilizing them to also be closed source.@Joe Bloggs Could Hiby make the R3 Pro firmware open source?
Then the community could fix the various issues.
Also on Qobuz the album title seems to miss information and many times two albums are treated the same.
And of course there are still many playback issues with error code -13. This is the same issue as for Tidal.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Exactly. And look at all these empty space in folder view. Why?? Could've fit 8 lines of information in one screen space. If you think we got fat fingers, fine, make the font bigger then.when i turn on my music player i want the sd card folder view to show immediately. i dont want to have to make 5 clicks before i can get to it
Does R3 support wipe-right-to-go-back gesture in folder view?
Can I use this version to change the limit in an R3 Pro Saber or is this for the regular R3?Firmware 2.1 (Custom) with 65000 limit and other my corrections:
2.1 International ver. (from Kickstarter);
2.1 Chinese ver. (from JD and so on, rename the file to r3.upt before updating)
I haven't really tested all the functions that they work normally. If you faced with problems, please, PM me.
For regular R3 onlyCan I use this version to change the limit in an R3 Pro Saber or is this for the regular R3?
I just bought one but didn't realize the limitation even when it supports large cards.
Thank you very much for your help
Has anyone with an R3 just had it straight up die? I've had my unit since 2019 FWIW. About a week or so ago, my R3 just died/turned off and there doesn't appear to be anything I can do to get it back online. List of things I tried below:
Anyone have any thoughts, ideas, or suggestions here? Thanks!
- let it charge for hours/overnight. The small charging/playback LED on the side shows no signs of life either
- remove/replace SD card
- hold various power/button sequences for 20-30 seconds each
You wouldn't believe it (or you would ha), but this did the trick! I can't believe I didn't try this earlier, but alas, many thanks!Maybe try charging from a computer USB port. I don't know why but sometimes it works for dead batteries. Maybe because of the lower current or attempted data? It may take a long time to kick start, of course. Nothing to lose, right?
