audioxxx
- Sep 1, 2013
Basically the back plate is a really thick sticker, you can use a spatula or something to get it off. Battery has a connector. Hardest part would be to get a replacement battery probably.
If it's just double sided tape then it should be easy to open, and I'm pretty sure the batteries will be made available as thousands of units will need them eventually.
Maybe as battery technology improves in time a bigger capacity cell will fit in the X5.
