Dobrescu George
Reviewer: AudiophileHeaven
Anyone know if the dynamic range listed on the website of fiio is correct? 101dB ? While the X1 has 110db ...
I really think that both units will give you enough dynamic range.
Maybe it is a mistype?
![biggrin.gif](http://files.head-fi.org/images/smilies/biggrin.gif)
You must be referring to http://www.amazon.com/gp/aw/d/B00KGHNPNQ/ref=mp_s_a_1_3?qid=1431711479&sr=8-3&pi=AC_SX200_QL40&keywords=Monoprice+otg&dpPl=1&dpID=41FEP3c1U-L&ref=plSrch
and
http://www.amazon.com/gp/aw/d/B009Z6A0KA/ref=mp_s_a_1_1?qid=1431710879&sr=8-1&pi=AC_SX200_QL40&keywords=Monoprice+otg&dpPl=1&dpID=31xt1BR68RL&ref=plSrch
What did you use as a microsd card reader with these?
It's a separate adapter:
http://www.monoprice.com/Product?p_id=11194
The other two adapters are also available directly from Monoprice.
Official firmware version 1.1 for the X3 2nd gen is now available.
>>Click here
The following changes and improvements were made to FW1.1 compared to FW1.0:
1. FiiO's slogan "Love Music, Love Life, Love FiiO" added to starting animation
2. "About X3K" renamed to "About X3" in accordance with official product name.
3. The microSD card is now identified throughout the menus as "TF card" rather than "TF卡".
4. Fixed issue where the status bar icons are shifted when the volume level is over 99.
quite an underwhelming update..
>>Click here
Anyone try this? I followed the instructions, but get "file system not supported' even though the card was formated with the X3.
i tried with a 128gb samsung andcdidnt work, but switched to an 8gb card and it worked fine.Anyone try this? I followed the instructions, but get "file system not supported' even though the card was formated with the X3.
Worked for me.
Not sure how my SD card is formatted though, I was using it in my Note 3 and transferred it strait over to my X3.
Whatever Andriod formats SD cards to is how my SD card is formatted.
Thanks for the reply. Just to confirm, you have tested and used this monoprice adapter with the X3 2nd Gen and it works? I am a big fan of Monoprice products, so if it does that is great!
Yes. I have successfully used all three of the Monoprice adapters.
To the extent that compatibility is a question in the OTG space, I think the storage device is more likely to cause issues than the adapters, although in my personal experience I've had two adapters that didn't work. But I don't think that is representative.
I think SSDs are particularly wonky, based on the firmware. If anyone has any experience with OTG and SSDs, please share!
