I think you're right.....
And that's where the difference between "the hobby" and "the science" comes in.
The differences between how various albums are mastered usually far exceed the differences between various high quality audio components - and this is especially true of DACs and amplifiers. Likewise, the single biggest factor is almost always the speakers, and how they interact with the room. Therefore, if the discussion was about "whether there are
significant differences between amplifiers or DACs", I would probably agree that, in most cases, there are not. And, of course, each of us has a different list of the factors we individually consider significant, and in what order of priority. While I can notice the location of various instruments in the sound stage, I simply don't find it to be terribly important, while others find it to be very important to their listening enjoyment. In contrast, I tend to notice small differences in the attack characteristics of struck cymbals and drums, while other people may not find those to be especially important at all. I also find any added pitch variation - vibrato - in voices to be especially annoying, but my overall sense of accurate pitch is average at best.
However, that's all what I would consider "practical engineering"...
But, if we're talking about real science, then we should stick to the rules for real science.
And, in real science, if you make a generalization, you should be able to prove it
FOR ALL CASES - and, if not, then you should not phrase it as a generalization.
If you mean "most of the time" or "for most people" - then you should be concise and phrase your claim in that language.
I am quite certain that, with
most well designed preamps and amplifiers, if you connect them together using various different interconnect cables, there will be no audible difference.
And, if I chose to, I could
falsely claim that was true with
ALL well designed preamps and amps and all well designed cables....
(I would simply claim that any equipment for which that wasn't true wasn't "well designed". However, in practice, that's just a creative form of circular logic.)
The reality is that certain older tube equipment, which was considered in its day to be well designed, had a very high output impedance.
And, over the years, a certain number of interconnect cables, also considered to be well designed, have had significantly different amounts of capacitance.
Because of this, when you combine certain equipment with certain cables, there is a clearly audible - and easily measurable - difference in frequency response.
This does
NOT in any way suggest that, for
MOST people, and
MOST equipment, and
MOST cables, there will be an audible difference.
It simply means that, just as my friend with the peanut allergy must avoid peanuts, the owners of certain specific equipment may notice audible differences between cables.
(And, yes, for most everyone else, they can safely assume that most or all cables will sound exactly the same with their equipment.)
I
DO apologize to the people whose lives this makes more difficult....
And for those whom it deprives of a cherished life-simplifying generalization....
And it in no way suggests that
MOST people should worry about which cable they buy.
(Just as most people I know don't bother to read the fine print on food labels to check for traces of peanuts.)
And, no, as long as MOST audiophiles believe such differences exist, that belief will drive the product sales market...
And, as long as that remains true, there is no need or incentive for manufacturers to even attempt to prove it...
(Remember that, even if they were to prove a difference, but it turned out to simply be less significant than anticipated, it would still be bad for business.)
No doubt that there's lots marketing BS and it has some influence. But I suspect that there's even more influence from reviews, opinions expressed in forums like this, opinions expressed by friends, etc. Other influencing factors would be product specs, product aesthetics, brand reputation and heritage, etc. All of those factors are big-time influential with performance cars, and I think these issues are general to the consumer mindset.
My current thinking is that the biggest issue with audiophilia isn't inaccurate or incomplete objective understanding of how different things affect sound quality, but rather the relentless search for better sound quality far past the point when 'plenty good enough to enjoy music' was reached. If people truly 'trust their ears' and recognize that what they have is good enough, the question of what makes sound better won't come up because people won't care about it. As I've said, I'm not immune to this problem myself. Does something like an Audioholics Anonymous exist?
