castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
isn't that what's all the audiophiles do? thinking that if they prefer something, then it's the real sound.
1. As I mentioned, no one has really come up with a musical genre/style which even takes full advantage of/relies on 5.1 yet. So a format which extends the capabilities of 5.1 even further is even more superfluous. No doubt we'll see the odd experimental album/track in Atoms at some stage but I can't see it becoming any sort of standard for music. The Object Oriented nature of Dolby Atmos is great for film, where we have a lot of moving sound sources (most of which are established/supported visually) but that's not the case with music, where all the sound sources are expected to be stationary and obviously with a music recording there are no visuals to support any illusion we may wish to create contrary to this stationary expectation. The fundamental problem though is economics. It costs more to build a good 5.1 mixing environment (and more still for a Dolby Atmos mix room/stage) and it takes more time to record/create the additional music/sound to put in those additional channels, considerably more time because with music there are no conventions to inform the arrangement/mixing. So, that's a lot more time, at a higher cost per hour, with a greater risk of failure and all during a time of decreasing revenues from music sales.
2. I agree that's what "some audiophiles seem to prefer", I'm not disputing they have that preference, what I'm saying is that what they appear to prefer is a fallacy which doesn't exist. Orchestral recordings are designed from the perspective of some distance from the orchestra. Actually sitting in the middle of an orchestra sounds completely different to just massively widening the stereo image of a distant orchestra. Just as recording a car in stereo from some distance and then massively widening that stereo image does not result in playback which sounds anything like actually sitting in that car. Maybe those audiophiles just have no idea what sitting in the middle of an orchestra sounds like or maybe they just don't care because they're into the sound of their equipment rather than the music. Either way, it makes a bit of a nonsense of their demands for higher SQ.
There's one of the big problems with audiophilia. What some of the more extreme audiophiles "like" doesn't necessarily have any direct correlation with SQ, however, because they are typically unable to make any distinction between what they like and SQ, we end up with all kinds of ridiculous claims and then ludicrous explanations to justify/rationalise those claims. Fortunately, you now seem to be making that distinction but unfortunately it doesn't really matter because what you want/would like: 1. Isn't really possible and even if it were, 2. There isn't enough of a demand for it.
I've never really understood what audiophiles mean by "soundstage", I'm presuming a combination of what we in the pro audio world call stereo image and depth/presence or audio perspective? To create depth/presence actually requires a change in frequency response and therefore the opposite of what you're saying is actually true. What you're really saying is that you want the FR of the instruments to change in line with how the brain expects the FR to change with distance/position, so that the change appears natural and therefore the brain's illusion of timbre is maintained. Unfortunately that's not really possible, it's like trying to change the ingredients in a cake after it's already been baked. With stereo we've effectively got two elements rather than just a single whole cake, which presents opportunities to unpick and rearrange the mix but, we can only unpick it to a limited extent and even what is unpicked can only be rearranged to a limited extent. Mostly this is accomplished by changing phase relationships, which as KeithEmo stated produces fairly unpredictable FR interactions rather than the FR interactions and other transfer functions actually appropriate to the instruments' new spatial positions. The results are surprisingly good, on a superficial level but fall apart on closer inspection. What's interesting about the "Indoor" tool I posted a video to (post #6525) is that it heralds a new generation of pro audio tools which automatically takes care of all the FR, phase, early reflection and reverb interactions (within a 360deg space) from different audio perspectives. In other words, it is now possible to automatically create a convincing transfer function appropriate to different/new spatial positions. However, it requires individually processing each element of the mix and therefore only solves half of this particular problem, as we can't yet un-mix a stereo mix and get at all those individual elements.
G
My sighted expectation bias appears to be on the fritz.
Yesterday I received my Anticables 6.2 ABSOLUTE Signature RCA interconnects which cost $600 after cryo treatment and 3-day burn in option. Right away I noticed the sound was cold and lacking in depth and detail. Sure enough, my no-name 15-year-old interconnects I found laying around the basement which was around $20 and made from pro cable stock as I recall, was not only much warmer but more detailed as well.
Anticables included an information sheet with the cables that warned that they need at least 100 hours of burn in before the start sounding as they should, and furthmore may improve with up to 500 hours. 3 days is more than a day short of the minimum 100 hours, so I let them run for another day. The result was that the Anticables lost much of coldness and resolution more-or-less caught up. My no-names from the basement are still warmer and fuller, while now sounding a bit more veiled in comparison. As of today the $600 cables are at best a side-grade.
If my bias doesn't improve the Anticables' sound significantly soon I will be making use of the 30 day return policy.
Interesting that you use the adjective "cold" to describe the sound from the cryo-treated cable. Does it smell like cow manure?
You're not helping my bias improve my $600 purchase sound quality.
I know this thread is old but I have to say thank you for the efforts put into this post with all the references (link). I have been lurking around this forum reading reviews and posts but never contributed. This post actually inspired me to register and contribute which I hope to continue doing.
As for the results in this post, for me, I believe it all boils down to common sense and people with a lot of disposable income (sadly some simply lives on credit). At what point do you perceive a discernible and credible difference between a $500 amplifier or $3000 one? To me it's more psychological and self-importance on the part of some so called audiophiles. The one I've never understood is paying $1800 for a headphone and then spending another $600 on cable upgrade!!! What kind of jobs are these people into? I'm a professional and makes me wonder if I'm doing something wrong with my life because while I will spend that much on a headphone, it just boggles my mind to even contemplate upgrading the cable. If a headphone cost that much and comes with a silly cable, why would I even consider it.
Having said all these, some of the cost of these audio equipment has to do with the quality of the item not just the sonic difference. Call me shallow but I care a lot about aesthetics as much as sonic output. So if two products have no conclusive advantage over each, I will readily pay good money (of course not in thousands) for the build quality in deciding which to choose.
Once again, thank you for this post and let's hope some of these self-important audiophiles exercise more common sense. I also believe the audiophile community have failed to hold these companies accountable, if anything, they have encourage these companies in fleecing the public by shunning out unjustifiably expensive rigs with outlandish claims.
