bigshot
"Soundstage" is the high end audio term for "placebo effect".
New Q!!
How do you feel (some really have feelings about this topic) about using headphone amps?
You can't be serious. Sure, with headphones you don't get a proper soundstage, you get a 'headstage', still...
This is hilarious beyond extreme :
Come Monday, with the "standard" (whatever that might be) equipment reintroduced in the system, one starts noticing what is missing compared to the better equipment listened to over weekend.
But it's a function of the headphones/speakers, not the amplifier. Anyone using the term in relation to an amp, has a long row to hoe.
This is what i mean: my amps are not the best, in numbers, but they do drive my Havi with ease, much higher volume and ill become deaf. I also dont hear clipping at -22dB.
Also, how can a louder (just louder! ) signal cause more soudstage/spacing/etc.... I guess it cannot
Well the answer to that is easy. The ear's equal-loudness contours are not parallel - the softer the music, the less you'll hear in the bass and treble and the greater the variation in the midrange, and this mucks up the positional cues.
It's true, though, that the Clip is gain-limited, so you can't push it into clipping.
Yes - but two amps of differing power, but played at the same volume wouldn't do this. Which is the point.
So... IF i dont listen music at "loud" volume, my relatively poor amps are enough given that they do not clip?
But if you want more power (=louder) you are going to the amp's limits and THERE you start to see differences.
Which, if im correct, means that an amp increases soundstage by placebo and, if you need/want it, higher volume.
Btw, i go for a good seal all the time so i can lower the volume to save my ears!Was that actually a question you posted, or were you looking for
