nanaholic
- Sep 2, 2010
I need a new computer case that manages cables better. I would be keen on finding some very quiet, yet efficient, fans to go along with it. Any advice would be greatly appreciated.
You should head over to silentpcreview.com and read their fan reviews. Basically you should start looking at 120mm fans or above to replace the standard case fans which are usually 90mm (but the nicer cases today usually comes with something nicer), and the other fan to get rid of ASAP is the crummy CPU cooler which comes free with the CPU.
Also it depends on how much computing power you need. If you don't need a lot an i5 Intel NUC is virtually silent requiring no effort to put together.
