castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
about poisonous brussel sprouts:
If audiophiles won't accept free digital EQ on the desktop, why would they accept a portable version just because it's encased in a fancy box, and more expensive? Wait a second... nevermind.
Back to the definitions problem. Basically, if you ignore the actual definitions of things, and apply words however you wish, then we cannot objectively measure things because we cannot know what to measure (they are making up the terms and what they mean). But when you do have them defined - e.g. poisonous or audibly transparent - then we can test it. And make predictions based on test results. Science! Don't want science, then don't make testable claims without evidence.
Get an iPod. They perform as well as any audiophile player.
http://www.kenrockwell.com/apple/ipod-touch-5g.htm
I'm looking for more than just measurements,; I'm looking for blind testing. Measurements are great, but in my opinion, they're only part of the story.
I was hoping someone could link blind testing between something like the AK vs. iPod vs. Clip vs. Cowon (or any combination of these or other DAPs).
it's not that hard to do, but then what headphone to do the test with? a super sensitive IEM that will make you hear the BZZZ BZZZ of the clip buffering, and the different levels of hiss of an ak(depends what model), and ipod? cowons are usually pretty quiet.
or get some clue about what is what from the impedances changing the signature of something like a SE846?
or some actually hard to drive headphones showing the limits of max volume on some DAPs sooner than on others?
if you really want differences, it's easy to get some with most daps. and once there are some differences, picking the "best" sounding one will be simple. the reason why it's so hard to pretend like one DAP is better, is because with specific needs, the ideal DAP will change.
in the end the less demanding the headphone, the less important the source. that's what I really believe after trying a few DAPs now. and I'm not saying that in an elite audiophile way, as if you would need great sources to go with great headphones. no I mean that a lot of headphones are a damn bother and force you to change your source to adapt to them.
