Tempotec V3 DAP - small, powerful, functional with Hiby OS
Dec 30, 2023 at 12:43 AM Post #77 of 823
Mine came in early YAY!
Some quick tips for those getting one soon!
USB C out to DAC/Headphone Amp (checked my Gryphon) works perfectly!
If you are a Qobuz User and get Error 400 go into settings and set clock/time it should then work fine for you.
Tidal is still MQA version, so as someone else said it will need an update.
Build quality is very good, sound is very good, I have a busy day and was not expecting this today but just initial thoughts I am very pleased! I will try to post some pics later!
Cheers!!
USB C out have good quality ? Thanks
Jan 2, 2024 at 1:12 PM Post #83 of 823
Jan 2, 2024 at 1:16 PM Post #84 of 823
Jan 3, 2024 at 9:31 AM Post #85 of 823
was looking at Shanling H2 before but this one looks better in spec.
I never thought about the H2 in that way, but it’s an interesting comparison…
If you pocket your DAP most of the time and plan to rely on HibyLink (V3) / Eddict (H2) remote functions or, other use case, you often use your DAP as a desktop DAC, these twos are pretty close! At $199, current full price for the V3, I would go with the H2: the lack of WiFi (H2) is not really a problem in these use case scenario, and I don’t see the dual AK4493 (V3) vs. single CS43198 (H2) as significant for what are still entry/mid-level DAP/DAC-Amp.
Jan 3, 2024 at 12:43 PM Post #86 of 823
My v3 arrived earlier today which considering I ordered it 7 days ago is fast delivery over Xmas/new year period to the UK. Easy to set up as the OS is same as my Hiby R3 ii so up and running in minutes, it’s a solid chunk in the hand definitely doesn‘t feel cheap or nasty in use and it can get LOUD with my Zero 2’s. Only cost £139 so i guess I could call it a bargain even though I have no genuine need for it other than Xmas whisky induced curiosity ;)
Here it is in comparison to my R3, (crap pics)
Jan 3, 2024 at 1:46 PM Post #87 of 823
My v3 arrived earlier today which considering I ordered it 7 days ago is fast delivery over Xmas/new year period to the UK. Easy to set up as the OS is same as my Hiby R3 ii so up and running in minutes, it’s a solid chunk in the hand definitely doesn‘t feel cheap or nasty in use and it can get LOUD with my Zero 2’s. Only cost £139 so i guess I could call it a bargain even though I have no genuine need for it other than Xmas whisky induced curiosity :wink:
Yes, I paid the same and I like it a lot. Decent power and well built.
Jan 3, 2024 at 3:21 PM Post #88 of 823
Do you like the sound on tempotec more than on hiby?
Also, does the v3 louder than the R3?
Jan 3, 2024 at 3:38 PM Post #89 of 823
In my early opinion I think it sounds cleaner than Hiby R3ii and I use a lower volume setting on the V3 to achieve same loudness as on Hiby (using 3.5mm output). The V3 has a slightly higher output power level than the Hiby (2vrms vs 1.9vrms).
Jan 3, 2024 at 3:55 PM Post #90 of 823
All daps sound so similar that id be lying if I said I could tell the difference if they were db matched in an a/b test, the V3 is louder due to greater output mw.
  • Back
