mrsergey
- Dec 2, 2016
How does it sound compare to hiby player?My copy of TempoTec V3 DAP arrived.
First impressions below. A proper review with a bunch of photos coming in a few weeks.
Build quality - great.
It’s an ergonomic, well-made piece of work. The playback buttons might’ve benefitted from a tiny bit more “clicky” feeling, but you’ll definitely know if you pressed it. Volume buttons (V3 doesn’t have a volume wheel) are slightly more tactile.
I’m not a huge fan of a glass back, especially when there is no protective case available. Okay, the front display and the back glass surface are covered with a thin film by default, but it’ll get scratched easily during everyday use.
As mentioned before: V3 runs on a HiBy OS, which I know very well from HiBy R2 II. The only difference I can spot is boot logo swap - TempoTec instead of HiBy.
How do I like HiBy OS in general? It’s okay, but not the best implementation of audio listening software. Quite specific, but functional.
Don’t be fooled by its Tidal support. Tidal requires you to confirm your sign-in every 24 hr, since it can’t save the token properly. I haven’t tested Qobuz, as it’s not available in my country.
Sound - I’ll write more about it in the review, after I spend enough time with this small brawler. To not keep you waiting: I’m happy with it and it seems to be just what I expected.
Any questions, anyone?
Does it sound better, worse or the same?
