my inner curiosity just wanted to see what was under the hood of the a55 player. i follwed an a45 teardown video that is similar to the a55.
Sony Walkman custom firmware (non-Android)
- Thread starter MrWalkman
Steen Pihl
Nope, as in the U2 song “I still haven’t found what I was looking for”!Ok because this config gives me more than enough bass punch. And I love bass! The bass is well defined and very spacious as well. Sounds beautiful especially with vocal jazz.
aceedburn
Ah, you’re using a 1Z right? Results are different compared to the 1A.Nope, as in the U2 song “I still haven’t found what I was looking for”!
Hinomotocho
As the firmware focus is on raising the 1A to the 1Z sound I've always wondered how the pure 1A firmware/tuning would sound on a 1Z.Ah, you’re using a 1Z right? Results are different compared to the 1A.
aceedburn
I tested this a long while back with Bogdan in a pre release firmware. Didn’t really meet the mark so we scrapped it. This was way before Walkman one.As the firmware focus is on raising the 1A to the 1Z sound I've always wondered how the pure 1A firmware/tuning would sound on a 1Z.
Steen Pihl
I've been very happy with your suggestion and enjoying it a lot! Its just that I had to "leave" the bass endorsement I was developing, because this modded 1Z is very good at going deep. So its very tempting to follow that route.Are you using the wm1z sound signature, J3 region, plus v2 and dac initialization on normal mode?
Also I've just bought the new Ares S cable from Effect Audio and that adds the body missing (in my world)! Thanks for the suggestion! Appreciated!
J3 improves over MX3
U has a lot of bass muscle, but it gets tiering when you actually starts to listen!
J is awesome , but lacks bass and treble defination. You get all of that in J3
E is also pretty good, but I don't like the slight echo there (see the Mindstorm map)
All is just for inspiration!
aceedburn
Yeah, there’s just so many combinations that would work with Walkman one. You just have to play around and find the sound that you like. The one I suggested is in my opinion the most complete sounding combo.I've been very happy with your suggestion and enjoying it a lot! Its just that I had to "leave" the bass endorsement I was developing, because this modded 1Z is very good at going deep. So its very tempting to follow that route.
Helderfb
Boa noite a todos. Você pode me ajudar?
Existem muitos fóruns sobre um SONY NW-WM1Z.
Comprei há 20 dias, aprendi sobre "MrWalkman", instalei com sucesso "Walkman_One_(WM1)_(21_09)
.zip 568,4 MB, dei para J (Japão, Bright e mais V2 )
https://mega.nz/file/CnJyCTIA#27UFrtvdhjdBC4zkbJGnAilYxi4z_5ww9n6mVKYjRtY
1- Existem outras opções de firmware além dessas?
2 - O sabor do som stock. O que melhora na relação ao Quente e Brilhante? Eu digo em outros termos, além do óbvio
proedros
english , please
AlexCBSN
You can check Mr walkman website, Here's the linkBoa noite a todos. Você pode me ajudar?
About the rest of the signatures, you have to check what's available and what suits you better.
Hope that helps
KurosakiHT
Just found a NW-A35, flashed the Walkman One and it sounds great! Btw anyone know how the region will change the sound since MrWalkman did say so on his blog. My currently setup is WM1Z tuning profile with MX3 region and Plus v2 mode
ljnew
- Dec 24, 2015
What's the settings for the absolute warmest thickest signature?Yes, "WM1Z" or "Warm" are two options for that.
aceedburn
Hmm. The golden question. And my preferred signature. I assume you’re using a 1A. After having tested probably hundreds of software test versions and fine tuning etc, the current Walkman one has a signature for everyone from bright sounding to warm sounding. I use the wm1z sound sig with region J3, DAC mode on normal, plus mode v2. This gives me the warmest, fullest yet detailed enough sound. I haven’t budged from this setting in months.What's the settings for the absolute warmest thickest signature?
aceedburn
Yes the different regions change the sound. It’s best to try them all and see which one you like. The most popular ones at J3, J, MX3. Here’s a chart done by a forumer some time back just to give you a rough idea on what the different regions sound like. I use J3 and think it’s the best for my tastes.Just found a NW-A35, flashed the Walkman One and it sounds great! Btw anyone know how the region will change the sound since MrWalkman did say so on his blog. My currently setup is WM1Z tuning profile with MX3 region and Plus v2 mode
Hinomotocho
I'd love to one day see a chart including the new regions and firmwares. I find it helpful to draw attention to different aspects of the music as I can be quite simplistic in my approach limiting myself to focusing on bass and staging.Yes the different regions change the sound. It’s best to try them all and see which one you like. The most popular ones at J3, J, MX3. Here’s a chart done by a forumer some time back just to give you a rough idea on what the different regions sound like. I use J3 and think it’s the best for my tastes.
After being on J3 since it became available I recently went back to trying E and MX3 but found J3 to be an ideal balance. Owning the 1Z I can't help but feel that Sony knew what they were doing so stick with that tuning.
Total: 30 (members: 12, guests: 18)
