Sony NW-ZX300
Aug 29, 2017 at 3:07 AM Post #136 of 12,862
I shall take your advice and give it a shot. I really wish they had a better screenshot :)
I wanted a better software than Media Go for a long time, this works really well actually it is somewhat similiar to what I had designed with foobar2000 so I like it this way!
EDIT: I thought it would be a bit laggy because its importing but Its finished now and is still somewhat laggy
Aug 29, 2017 at 3:22 AM Post #137 of 12,862
Such a pity.
Aug 29, 2017 at 4:39 AM Post #142 of 12,862
https://musiccenter.sony.net/en/?j-short=smc4pc
The new music transfer software - Music Center for PC. Appears to have gone live. Still at work and not able to try it but I'm sure other brave souls here would be eager to give it a spin.
Mine seems slightly unstable, crashed a few times. However MUCH better layout compared to media go.
I liked mediamonkey lot, this feels very similar to it.
Aug 29, 2017 at 4:54 AM Post #143 of 12,862
there was the official leather case ( which i am using ) CKL-NWZX100 for the zx-100 which is real leather has inner core of plastic coated with felt and magnetic closing action on the flap, thus, we presume that nw-zx300 will be ckl-nw300, considering nw-zx300 design is closer to nw-wm1, i presume the leather case will be similar
http://www.sony.com.hk/product/electronics/buy/zh/98869100
http://www.sony.com.hk/product/electronics/buy/zh/98868700
Again I can't find dust cover on the earphone jacks on any of these official cases…
Aug 29, 2017 at 5:01 AM Post #144 of 12,862
Only some cases from China comes with HP plugs, Sony official case does not have this, I think the Japanese version might get HP plugs, I think the wm1z and wm 1a does come with them. The Japanese version zx 2 also comes with the wm port plug.
Aug 29, 2017 at 5:15 AM Post #145 of 12,862
perhaps I'll stay in this topic
because recently I found out about this player.
Aug 29, 2017 at 5:19 AM Post #146 of 12,862
perhaps I'll stay in this topic because recently I found out about this player.
You are not the only one, I only recently came upon this thread, was thinking about getting the WM1A, might consider this more, much more pocket friendly, smaller and lite.
Aug 29, 2017 at 5:26 AM Post #147 of 12,862
I know that I was well satisfied with the design is that I feel that with the front display you will have problems and it will need to buy a protective glass.
Aug 29, 2017 at 5:30 AM Post #148 of 12,862
No difference with other player, you still need a protector, I even purchase 2 protectors and cases for the WM1A ahead of time, so I'll probably have to give those away if I do consider the zx 300
Aug 29, 2017 at 5:34 AM Post #149 of 12,862
in the past the player was not such a huge display, it was only half the player but this is all so the player can scratch when using the pants pocket.
