Feb 1, 2021 at 2:09 PM Post #4,577 of 4,753
It depends on the age and state of conservation of your pair. I made the mod to my older EX1000, that I later sold, and the foam shattered after removing it. In any case, it is possible to replace that foam with a new one, which in any case, I think is the most recommended.
Feb 3, 2021 at 12:53 AM Post #4,578 of 4,753
Are foam filters easy removable? I need to get them cleared and don't want to break anything.
I think you can use a sharp tool to dig it out. Btw I personally wouldn't do that, they disintegrate easily and it's very hard to insert it back in one piece after removal.
Feb 8, 2021 at 3:21 AM Post #4,579 of 4,753
I received my 2nd EX1k unit few weeks ago, as I observed my 1st set was not as good as what I read here and the left earphone's spiral thread was broken can't change to fit ETK adaptor. This 2nd unit is so much improve the sound, i.e. clearer and wider , very much detail and neutral (but not boring) as I able to listen to more previously hidden or partially hidden music instruments.
Smooth and comfortable soundstage especially on classical music , it's like i am sitting middle of concert hall and it's like end game to me after trying many variety of IEMs.
One thing want to ask here is if the foam filter is further pushed inside, I can see them with torch light? The foam filter is not flushed with the nozzle as my EX800ST. There's no foam filter on my 1st set.
Feb 8, 2021 at 7:13 AM Post #4,580 of 4,753
The filter foam is recessed about 1mm from the tip of the nozzle in my EX1k.
Feb 8, 2021 at 9:17 AM Post #4,582 of 4,753
thanks, but I checked mine both sides foam filters have been pushed 5mm inside , probably by the former owner. Not sure if the sound still the same as recessed?
But first set is without foam filter, it sound quite plain and dull.
Feb 9, 2021 at 9:38 AM Post #4,583 of 4,753
Where could one get hold of replacement foam filters? Mine are starting to disintegrate I think...
Feb 9, 2021 at 11:47 AM Post #4,584 of 4,753
Is the price of around 250 usd (without counting tax, import, shipping fees) for the EX1000 in a "good" condition (amazon) a good price?
Feb 9, 2021 at 12:43 PM Post #4,586 of 4,753
Yes, that's a very good price. I bought mine around $400-450. Are you sure it's ex1k? $250 is the going price for EX800ST. They look very similar.
I bought it, it was from amazon japan so I am safe if it is a scam.
I do have the EX800ST and thats why I was interested in the EX1000 but never pulled the trigger due to the price. So this was too good to pass on.
Feb 9, 2021 at 8:34 PM Post #4,587 of 4,753
Ya, it's good price, remember to ask seller if the foam filters are still there as my first set is without foam filter.
For the 2nd set, I got it around 26000 yen (USD 258) from Buyee.jp including shipping, handling and tax. Good quality and no paint peel off and it looks like new.
Feb 10, 2021 at 8:46 AM Post #4,588 of 4,753
They already shipped it lol.
Its from amazon, so I can return it if there is any problems....
Not having any foam filters on it will just increase the treble right? I do think I will need to eq it anyway so if thats the only difference it doesnt matter much to me.
On that note I just noticed that my EX800ST (used) came without foam filters lol. :joy:
Feb 10, 2021 at 9:09 AM Post #4,589 of 4,753
Without foam filter , i find the sound is dull and flat. I don't use EQ that much, usually I will refer the IEM frequency graph as my shortlisted to suit my music genres and taste.
Hope you will enjoy your EX1K , cheers
