BaltColts
- Sep 27, 2014
Thanks
Not fewer cable, they don't supply you with the ex1000 cable, a alternative cable, and is not four stands, so you can't re-terminate to 4.4 Pentaconn plug.
It comes with two cables, ex600 one long and short.
A friend of mine got both short and long ex600 cables, from a local US store.Mine only came with one ex600 cable, and was new. So yes, try to not buy the US version, un less it's a really good deal
Yep, same as Japan, Hong Kong and Macau.The Chinese market version comes with two cables, one 1.2m and one 0.6m long (7N purity OFC copper).These cables are of higher quality than the US market cables, slightly thicker too.
If anything to go by it should be identical to the long version.Hey guys, I received my brand new EX1000 today, havent’t yet unboxed it. So excited
Anyways, I also bought one additional RK-EX1000SP cable (the shorter 0.6m version of the original EX1000 cable) in order to transform it into a balanced cable. For this purpose I also bought one Oyaide 4 pole 2.5mm TRRS plug and left both the plug and the cable at a local cable workshop in order for them to reterminate it for me.
Can anyone confirm whether the original short cable comes with 4 strands (2 per channel)?
