I got a reply from Mike Smyth to my "workaround" proposal. He thinks it is an excellent idea but it can't be done now and the reason why can be a bit of a shock:
Hi Sander,
The idea is excellent, but unfortunately it isn't possible with the A16 at this moment.
The problem is the current HDMI interface board from MDS that we are using - it doesn't allow more than 2 channels to be output. The previous version of the board allowed 8 channels to be output, and the next version of the board (using a different HDMI transceiver) will also allow 8 channels to be output - but the version we are using only allows 2 channels.
But it's certainly something that we should consider in the future - for this type of application.
Very best regards,
Mike
So out of the window are my plans to use one of my current 7.1 av receivers (without analog 7.1 input, only HDMI LPCM 7.1 input) to amplify 7 of the channels for use with real speakers.
So I asked more specific questions about this:
Hello Mike,
Oh, I guess this also means that I can not use my legacy 7.1 receiver without analog 7.1 input but with 7.1 LPCM input over HDMI to amplify 7 of the output channels in AV Amp mode? (And 7 more channels with my older receiver that has 7.1 analog input).
But it is not a disaster, I can buy another dated used 7.1 amp with analog 7.1 input.
I assume the AV Amp mode stil wil be implemented (using the analog outputs)?
And in the HDMI pass-through mode? If LPCM 7.1 was coming in to the Realiser HDMI input would it be passed through? And all bitstream formats?
Regards,
Sander
And his reply was:
Hello Sander,
The limitation I described is when the audio bitstream is being decoded and the video bitstream is being looped thru the unit. Essentially you can't inject more than two channels of 'generated' audio into the looped-thru video. It's a physical issue in the design of the HDMI board - MDS switched to using Silicon Image devices in order to accommodate HDR but the downside was this audio restriction in the output channels.
However in stand-by mode, where you want to by-pass the A16, then the audio and video bitstreams (including 7.1 pcm) should both loop-thru the A16 without any alteration. In this case you could use your current AV to receive this signal, and decode it as normal. This is a sort of 'active' standby (or pass-thru) since the HDMI board is powered up.
Yes, the analogue outputs will provide a standard AV mode of operation.
Hope this helps.
Mike
