So the hf5's arrived today, and my first impressions were pretty varied.
First thing I did was attempt to get a good seal with the triflanges that came already fitted; bad idea. Whilst I did get a decent seal for a while, it was terrible comfort wise in my opinion. They even went as far as to get minorly painful. Next I tried the Glider tips which are quite nice when sitting still but when moving, they kept getting pulled out of my ears. It may be that I didn't inster them deep enough; but the best seal I did manage with them was from a kind of pushing and twisting motion. Finally I tried the foam tips which looked comically massive, but I find that they are the best tips for me out of the lot of them. They isolate insanely well; reduce noise from cable movement a little and they stay in a little better than the glider tips. As for the configuration at which you place them in your ear, I don't particularly like that you don't have an over ear option. Nevertheless, it is still very comfortable straight down.
As for the sound; My initial test is unamped with an Ipod nano 8gb (5th gen) I initially didn't think much of them. They sounded a little tinny with the highs, and lacked bass. However; upon turning the EQ off and pushing them a little deeper into my ears, the experience changed like night and day. They seemed more balanced and enjoyable to listen to, with a better bass response and a more natural feel. The hf5's seem far less congested than other IEM's I've listened to, and seem to have good separation between different sounds which I have noticed the UE200's (the IEM's I'm upgrading from) struggle with. From this, I must agree with the general consensus that they are very analytical.
One thing I have noticed though is that they make low bitrate mp3's sound like utter crap. I now need to re-rip all of my CD's
. I can see why people that are into R&B and the like may not enjoy these due to the non-bloated bass response, but currently listening through some of the various genres of my choice; I feel that they suit all round perfectly. All I need to get used to now is being able to hear my tinnitus more clearly; and the stiffness of the articulation in my neck when I look up. Ahah. Comply tips are definitely on the "to buy" list.
Final notes:
Pros:
*Amazing balanced sound
*45 degree jack is a plus
*The foam tips included are very comfortable.
*Great isolation and build quality
*Very easy to drive by the looks of it (only needs half the volume the UE200's do)
*Worth every cent (in my opinion)
Cons:
*Cable is a little loud when not using the clip
*No over ear option
*Triflanges evidently not for everyone.
