Shanling M30 - Concept announcement
jmills8
Previously known as bmiamihk, jmills2
5 watt Romi Amp.What is that, an amp?
jeffhawke
Yeah, right? Means "INFINITE ASSES" in Spanish. Maybe a hidden reference to us audiophiles
Using the 3.5 mm hole and photoshop I estimated the width of this device to be about 17,5 cm (±0,5 cm) and thickness about 4 cm.
About the same size as a QA390, with much nicer aesthetics (IMO). If it comes close to the 390 in terms of output, it'll be quite something.
LeFaucon
- Dec 8, 2013
WOW great !5 watt Romi Amp.
Would you kind enough to give us the exact reference for I didn’t find it
Thanks and cheers
- Oct 14, 2013
Basically this is a minimized piece by piece system, and making it smaller to the point of transportable. So you have a transportable system with different pieces to upgrade independently
the only differences is that you are stuck with Ribbon interconnects connectors. There is no Fancy Effect audio interconnects, no Kimber Axios, no snake oils to play with ! . So there won’t be choices between Gold-silver-copper flavors of the month anymore .....Could be a good news or bad news
Pretty designs for sure
jmills8
S/N Ratio >125DB at 1KHzWOW great !
Thanks and cheers
THD : < 0.002%
Bal-Gain:+8DB(Lo-gain);16DB(Hi-gain)
Bal Output Power: 5000MW / 25 ohm ,3000MW / 40 ohm,1200mw/100 ohm
Output impedance: 1ohm
Input impedance: 49K ohm (3.5mm) ,98K ohm(2.5mm或4.4mm-Bal)
Frequency Breadth (Bal-input): 20Hz - 20KHz ( +/- 0DB )
Power Requirement:DC IN 5V (TYPE-C,3A電流)
BATT:3.7V聚合物鋰電池,容量8000mAh
Size: W93 X L137 X H28 mm
Operating ambient temperature range:-40℃~85℃
What is this amplifier? Still unclear. Can I know the full name of the model?S/N Ratio >125DB at 1KHz
THD : < 0.002%
jmills8
Romi Audio in Hong KongWhat is this amplifier? Still unclear. Can I know the full name of the model?
KESM
- Jan 25, 2014
- Oct 14, 2013
M30 ? Will we have M30Pro later ? You know ? The trend
gto88
- Dec 11, 2014
ROMI-AUDIO Balanced Headphone AMP - RA200AMP-plusWhat is this amplifier? Still unclear. Can I know the full name of the model?
chaiyuta
No, historically Hidiz and Hiby use 'Pro' wording to described the enchanced version of a device. In case of Shanling, it might be 'M30s' or 'M30x'.
purk
- Sep 26, 2001
I feel being cheated by Sony. Only MKII and not “pro”. Join the “pro” movement Sony! My WM1Z sound less cool than WM1A Pro!M30 ? Will we have M30Pro later ? You know ? The trend
gerelmx1986
I think theyre mhssusing the "pro" word, they sont really know thes chinese people what po is really behind. For me pro is for professional use e.g cinema industry cameras vs cybwrahot or pro atudio and stage amps vs a TA-Z1ESI feel being cheated by Sony. Only MKII and not “pro”. Join the “pro” movement Sony! My WM1Z sound less cool than WM1A Pro!
