AladdinSane
- Jun 16, 2013
Never figured out how to slip in a Canon L lens. The different color was too obvious. Glad I (mostly) stayed away from that hobby!
Hi all.
I posted a few weeks ago about receiving my HD600 and a modi/vali combo. High end seems too tame for my 60 year old ears. It was recommended I try some brighter headphones. I did. Tried a pair of Beyer and a pair of v-moda. They were brighter. Problem was I couldn't wear them for any length of time. So,I know it's admirable to make an amp neutral,but is there an amp or amp/dac combo that would be brighter than the Schiit combo?
Thanks for any input.
Howard
I can afford either the Hd 700 or the divorce attorney,not both
For some reason I thought the SYS might be able to do this, but I'm really not sure. Is there something from Schiit, or anywhere for cheap that would let me switch the RCA input from the Modi 2 Uber to the Vali/Valhalla 2 without actually unplugging the RCA cables every time?
Thanks!
A RCA Y adapter would work. I use this one from audioquest with good results:
they also make a flexible one, i've used both, both are excellant
Thanks!
The flexible one may be a better option if you stack the Vali on top of the modi. On the gold plated adapter, the RCA's from the splitter end up blocking the RCA input of the amp on top (Magni/Vali). You can turn the adapter so the RCA's are horizontal, but then the cables get in the way of the inputs on the Modi a bit. With the flexible adapter there wouldn't be these issues.
Thanks for the information! Those gold ones look great, but might make stacking...interesting. Will probably go with the long ones.
I have 2 new-in-the-box of the gold ones by Audioquest. Got them for a preamp that I ended up not buying, so I don't use them. They're $13 on Amazon, make me a lower offer if interested and I'll send them to you.
If you mean the long cable ones, maybe. Though is there any issue with using a Sys, cost aside? Would it degrade the signal at all? Not the best option due to being more expensive than an adapter, just curious.
With the cable method, would both amps work at the same time from the same source? Obviously they would play the same thing at the same time. I guess I'm just worried about any signal degradation or volume loss or something.
I also found this: http://www.monoprice.com/Product?c_id=104&cp_id=10429&cs_id=1042904&p_id=7186&seq=1&format=2
That might possibly fit behind the Modi. Might have to rotate them a touch.
i used both splitters with the modi, and modi 2u, allowing me to use two amps at the same time, one tube, one solid state, i couldn't detect any detrimental effect's at all, jason said that there may be some loss of volume, but if there was, i'd say it was VERY minimal
i started to get the mono price adapters, if space is tight behind your schiit, they could be a better solution, the flexible audioquest splitters are 6" and kinda stiff
