CJs06
- Mar 4, 2008
Don't get me started on cables...
True that
Don't get yourself started.
Anyhow, I wanted to ask what people's experiences were with tube rolling the Valhalla. I thought I might hit eBay or the tube shop in Taiwan (since it is near Fukuoka and cheap) to find some inexpensive tubes to roll, for fun.
I got my Asgard 2 this morning. After two hours' use it has become really hot that I think I can cook on the amp. Is this normal to other amps? I can't even adjust the volume because of the temperature.
My Lyr 2 came this morning, same here, biased well into class A. My main system has a giant Krell Amp, same result, a great space heater during the Winter, a sauna during Summer .
This beast has a chokehold on the 650's low end, no muddy, diffuse bass here, mid's have a bit of tube magic, haven't listened to any jazz or classical yet, so the top ends a bit of a mystery yet. Now if I can have the patience to learn the amps basic sound before I start rolling tubes!!!
I like the sound on Asgard. I can hear more detail now with my HE400 than when I used K550 with a op amp Cmoy, but there seems to be some humming sometimes. I listen to CDs, so does the noise come from the source(recording problem)?
Probably a ground loop, you could plug it in with a two prong "cheater" or I am using a Sound Wedge that isolates and "traps" (so they say) noise. Though with everything plugged into my two "wedges" I have never had any hum issues. Monster and others make similar, less expensive products.
hi;
just joined the rank i got a MAGNI from
Billheiser before this I was useing the cmoy amp .
very happy thus far oh though I can tell a bad recording more now .
Ad700 headohones love it .
next is the usb dac from them.
