Solrighal
- Jan 27, 2005
Hi
Was just wondering if anyone had tried the 200 gig microsd card with the clip plus yet? I know that 128 gig works fine!
Nope, sorry.
Hi
I have RHA 750 and Android phone. Will the quality of sound output improves with Sansa Clip+ ?
edit: mostly listening to mp3, no flac and similar
Perhaps not so much anymore, as the 4GB Clip Zip is now $75 on Amazon,and the 8GB one is $100. On Ebay refurb 4GB ones are only $30 though. Normally I don't like buying refurbs, however at less than half the price of a new one, it is worth the risk to buy a refurb(or two of them in case one doesn't last long.
Where did you order the clip from if you don't mind me asking?
I got it from MyMemory for £25 but I think they are all gone now.
I bought a sansa clip used for only 17 dollars, been using it for almost a year. My first sansa clip lasted about 2 years. Built quality is crap, but they're cheap.
