CMasten
- Feb 20, 2006
I find the medium gray silicones to be absolutely perfect for me.
Originally Posted by lhamp /img/forum/go_quote.gif Am I the only person who actually likes the medium gray silicones? For me the achieve a great seal and are really comfortable. Are there any other variables to consider when choosing a tip? IE, do tips actually sound different, or is it the seal that is effecting the sound? Thanks all... first post and very new to this. |
Originally Posted by lhamp /img/forum/go_quote.gif still playing with tips... has anyone found the gray silicones to be too bass-y, or more specifically, a little boomy? For me, the large gray silicones are the only ones (cut down triple flanges included) that give me a true seal... and they're really comfortable... but I believe I might be hearing a bit a veil over the music: a little murkiness and a little boominess to the bass. Granted I'm listening to an iphone, but... Keep in mind I'm in that early, craziness stage... I might just be looking for stuff. |
Originally Posted by Big Kev /img/forum/go_quote.gif I've just started using Spyro's that he just sold me and have found the bi-flanges to be lacking in the treble department, with the same problem whilst using the large grey silicones. The olives worked well, but were so tight, that I had to cut them off, as I didn't want to break the nozzle, which is a shame, as they were very comfortable, isolated very well, delivered great bass, as well as good treble. I tried a set of tri-flanges from my E500 days and they are quite good, although they might need trimming a bit, which may improve the treble. I haven't tried the Complys yet, so I'll try them over the next couple of days. No real sibilance issues either so far, fingers crossed, so I'm pretty happy so far. |
Originally Posted by fredman22 /img/forum/go_quote.gif Me. With my UM2s, the Shure grey softips were a no-brainer. With W3s they are not a slam-dunk, but like many others I have not found another tip that is even close to working as well. I'm using Sony DAPs and have found a couple of EQ settings I can live with that tame the bass output (and that helps greatly in restoring mid presence & overall balance) but I'm finding it very recording-dependent (much like sibilance). Still, these sound very, very good and easily outclass the UM2s with their extended range. Cheers. |
Originally Posted by AndrewF /img/forum/go_quote.gif I just try not to completely jam the silicones in my ear, and they sound great. |
Originally Posted by Spyro /img/forum/go_quote.gif Yes, the are better than UM2's EXCEPT for vocals. If you still have the UM2's go back in forth between W3 and UM2 with vocal driven music (something like Diana Krall). It's not even close. I was kind of shocked myself. |
