REVIEW: Vivo Xplay 3S + XE800 Mobile audio perfection
24 25 26 27 28 29 30 31 32 33
35 36 37 38 39 40 41 42 43 44
  1. Turkleton
    Day to day use I'm using a smartphone - Xiaomi Redmi Note 3.
    When I A-B'ed the two, I tested with Fiio Q1 DAC/Amp. The only DAP I have is the Xduoo X2 and it's strong enough to drive the Havi's.
    Some other users have recommended the Topping NX1 as it supposedly pairs well with the Havi's.
  2. squallkiercosa
    For those who got the Xe800 for ~18$, is the nozzle metal or plastic? Does the driver flexes?
  3. mircam
    1. metal
    2. yes
  4. yangian
    I found some inconsistency:
    https://www.aliexpress.com/item/100-Original-VIVO-XE800-High-definition-moveable-Hifi-Sound-system-in-ear-earphone-with-mic-Voice/32704376144.html?spm=2114.01010208.3.1.mSWiFq&ws_ab_test=searchweb201556_10,searchweb201602_1_10065_10068_10067_112_10069_110_111_418_10017_109_108_10060_9999_10061_10062_10057_10056_10055_10054_10033_10059_10058_10073_10070_10052_10053_10050_10051,searchweb201603_3&btsid=f0f69c28-f4ef-4324-ae2d-bae76f3fff81
    1. Resistance: 9Ω
    2. Sensitivity: 123dB
    3. Frequency Response Range: 8-25000Hz
    https://www.aliexpress.com/item/Original-Vivo-XE800-in-ear-HiFi-earphone-with-mic-for-smartphones/32649424538.html?spm=2114.01010208.3.11.VT8or3&ws_ab_test=searchweb201556_10,searchweb201602_1_10065_10068_10067_112_10069_110_111_418_10017_109_108_10060_9999_10061_10062_10057_10056_10055_10054_10033_10059_10058_10073_10070_10052_10053_10050_10051,searchweb201603_3&btsid=f0f69c28-f4ef-4324-ae2d-bae76f3fff81
    1. Resistance: 51Ω
    2. Sensitivity: 110±2db
    3. Frequency Response Range: 5-30000Hz
    https://www.aliexpress.com/item/Original-Vivo-XE800-in-ear-HiFi-earphone-with-mic-for-smartphones-GEVO/32701902851.html?spm=2114.01010208.3.20.IMiiQc&ws_ab_test=searchweb201556_10,searchweb201602_1_10065_10068_10067_112_10069_110_111_418_10017_109_108_10060_9999_10061_10062_10057_10056_10055_10054_10033_10059_10058_10073_10070_10052_10053_10050_10051,searchweb201603_3&btsid=f0f69c28-f4ef-4324-ae2d-bae76f3fff81
    1. Resistance: 51Ω
    2. Sensitivity: 110dB
    https://www.aliexpress.com/item/VIVO-XE800-Headset-High-Definition-Moveable-Hifi-Sound-System-In-ear-Earphone-With-Mic-Voice-Control/32737423932.html?spm=2114.01010208.3.54.I7JNLz&ws_ab_test=searchweb201556_10,searchweb201602_1_10065_10068_10067_112_10069_110_111_418_10017_109_108_10060_9999_10061_10062_10057_10056_10055_10054_10033_10059_10058_10073_10070_10052_10053_10050_10051,searchweb201603_3&btsid=f0f69c28-f4ef-4324-ae2d-bae76f3fff81
    1. Resistance: 32Ω
    2. Sensitivity: 101dB
    3. Frequency Response Range: 20-20000Hz
    https://www.aliexpress.com/item/100-Original-VIVO-XE800-High-definition-moveable-Hifi-Sound-system-in-ear-earphone-with-mic-Voice/32732459037.html?spm=2114.01010208.3.112.q1pzgy&ws_ab_test=searchweb201556_10,searchweb201602_1_10065_10068_10067_112_10069_110_111_418_10017_109_108_10060_9999_10061_10062_10057_10056_10055_10054_10033_10059_10058_10073_10070_10052_10053_10050_10051,searchweb201603_3&btsid=f0f69c28-f4ef-4324-ae2d-bae76f3fff81
    Frequency Range: 5HZ- 30000Hz
    Impedance: 50ohm
    Sensitivity: 110dB
    and etc.
    So which is the genuine one? I mean what is the true resistence, sensitivity, and FR range?
  5. Pastapipo
    This one looks completely fake to me. They used some official photo's, but the first en last picture gives it away. Also $5 is too cheap. Don't bite the bait.
    Legit as confirmed by @yoowan
    Legit, confirmed by me.
    Could be legit; pictures, story, price, everything looks legit. But at $23, you could avoid the risk and go for the $18 ones.
    Could be legit, does have the story, price and some pictures (although not taken by the seller himself).
    Official specifications from official website:
    1. Specifications
      Cord length: 1.25m
      Connector: 3.5mm plug
      Rated power: 10mW
      Max power: 50mW
      Frequency range: 5 Hz-30000 Hz
      Rated Impedance: 50 ohm
      Response rate:110 dB
    2. Mic Specifications
      Frequency range: 20 Hz-16000 Hz
      Response rate: --42±3dB
      Interface definition: L/R/GND/Mic
  6. yangian
    Thanks for the offical website!
    It seems the $18 is a different product:
    1. Resistance: 9Ω
    But seems good also. This might explain why someone claimed it sounds like Gr07 and someone claimed not!
  7. harry218
    I don't think the seller really paid attention to the official specs. Could just be a random specs from his old listing. I don't think there are many versions of XE800 either. Just the fake and the genuine ones.
  8. scizzro
    Recently ordered the$18 pair from ali. I am looking for an upgrade to the kz ed9, and the Senfer 4in 1 was a huge letdown for me. Hope these fit the bill :)
  9. mircam
    Why "Senfer 4in 1 was a huge letdown for me" ? Senfer 4 in 1 is on my list after I received Vivo xe800 :frowning2:
  10. toddy0191
    Judging by your comments on the 4in1s i think you'll like the xe800. Just received my second pair after my daughter stole my last pair.
    The are really well balanced and if you get the right seal have a decent amount of sub bass.
    You may like the tenmak pro which sound very similar to the xe800s with more bass.
  11. rikk009
    I just got these from Aliexpress. First impressions doesn't impress me. Does it change after  burn-in? How to check if these are genuine?
  12. rikk009
    Metal nozzle and yes the driver flexes.
  13. toddy0191
    Just A/B'd my new pair with the pair I gave to my daughter not expecting to hear much off a difference.
    What i found was noticeably more bass presence on the (very well) burned in pair and a slightly more spacious sound.
    So now I'm a firm believer in burn in!
    Either that or there are slight differences in manufacturing.
  14. peter123
    Just to confuse you my experience is the total opposite, the XE800 is collecting dust while my B3's still get some usage after owning them for over two years.....
    Just goes to show that it's all about personal preferences so better try for one self than putting too much into every single opinion.
    Good luck :wink:
  15. Level
    Thank you.
    Perhaps.......more wax = less bass?
    I'll have both in hand very soon and be able to see how deaf I really am.
