REVIEW: Vivo Xplay 3S + XE800 Mobile audio perfection
Mar 30, 2020 at 12:11 PM Post #677 of 682
hakuzen
everything is there the nozzle rotation is working fantastically, but sadly I don't think you can get it if your in Europe or the USA..This seller only ship to Asia
that's great, congrats!!
i already have got a chinese mailbox..
Apr 3, 2020 at 1:37 AM Post #679 of 682
brianforever
Singapore
anyone knows the purpose of the tuning key for the XE800 ?
Apr 3, 2020 at 3:34 AM Post #680 of 682
hakuzen
some units come with clogged vent holes. the key can be used to unclog them, but you can also use it to make them wider, in order to alter lows response (beware if you plan to do this, because if you oversize the hole, the fix won't be easy -adhesive tape with hole-). you get louder bass when enlarging the holes.
Apr 3, 2020 at 10:10 AM Post #681 of 682
brianforever
Singapore
Thanks Mate that's great information, appreciate it :)
