REVIEW: Vivo Xplay 3S + XE800 Mobile audio perfection
Jun 8, 2017 at 12:09 PM Post #646 of 682
BunchOfAtoms
Some outer-world computer's memory
From the current listings on AE, other than the Rillpac store, has anybody purchased from any of the 3 other stores? My friend liked the quality and didn't want to ask it back. I want another pair because i just love the SS. :)
Are those from Rillpac store original? I'd like to buy this IEM but there are a lot of fakes out there.
Jun 8, 2017 at 3:54 PM Post #649 of 682
toddy0191
North East England
No, it's not. I sent a message to the seller and she naively said they're fake. Well, at least she's been honest.
I think the best option would be buying that on Penon Audio's ebay shop.
The ripillac store xe800 are genuine, at least they were when I bought mine last year. There are recent eviews showing pictures of genuine products i.e. horseshoe clip, vsonic logo on tips and moveable nozzles.
Jun 8, 2017 at 8:04 PM Post #650 of 682
hakuzen
Jun 9, 2017 at 7:59 AM Post #651 of 682
endia
istanbul
Jun 22, 2017 at 4:06 PM Post #653 of 682
fairx
Gin no Kuni, Malaysia
Guys ive been searching this thread for info buying replacement tips. It seems normal tips 4mm inner diameter are too loose for xe800. Anybody could suggest where to get? I can order form aliexpress but cannot from Amazon or western store.
Sep 12, 2017 at 8:40 PM Post #654 of 682
scizzro
So my XE800's finally broke, and rather than get a replacement, I'd like to upgrade. Does anyone know a set I can look into? I'd like a similar tuning with a bit more bass.
Oct 5, 2017 at 2:37 PM Post #656 of 682
Cya|\|
Feb 2, 2018 at 11:41 PM Post #657 of 682
Singleton
@fairx Sorry if I'm a bit late but I'd recommend the medium sized Comply 200 tips since they are made from memory foam and won't fall out for most individuals and fits the Vivo XE800 nicely.
Feb 2, 2018 at 11:43 PM Post #658 of 682
fairx
Thanks. It means 4mm inner bore right? Actually recently I just order a replacement with 3mm inner bore. I'll. Report of its any good
Feb 2, 2018 at 11:48 PM Post #659 of 682
Singleton
@fairx Yep Comply 200 fits all IEM's that has an inner bore size of 4mm plus the medium size ones will be a perfect and comfortable fit for most individuals. Hope this helps.
Feb 3, 2018 at 12:02 AM Post #660 of 682
Singleton
Also I've personally have a box filled with Comply 100, 200 and 400 all medium sized fits all of my IEM's perfectly plus I have the Comply fitted on my IEM's for a 3hrs+ music marathon with no discomfort or issues. Hope you'll enjoy the Comply's :)
