brat
- Feb 20, 2005
Any idea as to where I may obtain this opamp? Is an adapter required?
Edit: Is this the same opamp? It's listed as LME49860NA.
Yes, mine is LME49860NA too. My mistake.
SRH-840, k701 and ATH-A700 and all of them like this op-amp most. Linear FR, natural highs, superb bass impact, good soundstage. Far more suitable for my current headphones than the flat and bass-less EarthTry it![]()
Yeah I wouldn't say Earth is bass light either, but I do find instruments lack some weight and impact compared to the ada4627-1brz. It did occur to me that his cans may require a boost in the lower regions, but the LME is cheap and I'm curious to see if I can find some more magic with it and the right tube combination in the Lyr.
And yes, the LCD-2 delivers adequate bass. Lol.
Try the cap mod on the Earth module ( 1uf PIO of 60V rating or greater across the HDAM's + - PS pins in parallel). That little mod helps deliver what you describe as lacking in the Earth module. I use K42 series PIOs for this job and it's a perfect match. It works equally well on the other 2 module flavors but I find for the A-gd gear (using A-gd HDAMs) the cap modded Earth gives me the most natural presentation of the 3. Of course that's just preference on my part.
The K42's are cheap but work very well.
Peete.
Peete,
I did the mod as you suggested with the Earth module with the K42 PIO. Just been burning in for the past 10 hours. Early impressions shows a deeper soundstage and a bit airier in the highs. Details are much clearer than before. I had the ground wire attached in the FUN. This seems to affect an almost pinched quality to the overall sonic picture and the bass seems recessed. Leaving the ground wire unattached seems to produced more natural sonics and the bass more apparent. In both configurations, voices seems to be more forward. Did you have the ground wire attached in the FUN?
Yep I left the GND wire attached. The only drawback to the K42 is the long burn in time....you'll hear some rather odd things (slight in effect for the most part) until it settles. Be patient during this process as the end result is well worth the wait.
Peete.
This is rather odd. The BA Mod I did with the Earth Module with the K42 on the FUN started sounding rather odd. There is distinct loss of air and sparkle in the treble. Sounds very dull. Its been almost 250 hours burning in. Is this normal for such a drastic change in the sonics? Reminds me of those times when first burning n the Earth HDAM and the FUN, but certainly didn't expect the K42 cap to display such change in sonics. I'm beginning to wonder if the K42 cap itself is a dud.
