Review of the Audio-GD FUN - A modular Dac / Headphone amp / Preamp
Oct 24, 2011 at 9:43 AM Post #1,231 of 1,252
I think the BA Mod with the Earth HDAM has finally settled after almost 3 weeks of burn-in. The sparkle and treble have return after disappearing for about a couple of days. The modded Earth in the FUN seems a totally different beast now. No longer does it sound clinical with a touch of fizziness in the treble. It now sounded natural, quite airy and good separations and depth of soundstage. One thing that really impresses me about this mod is how it affects the dynamics swing of a piece of music. Quite a difference between soft and loud passages. Love the way it sounded in orchestral music, with strings sounding as they should and proper delineation of the woodwinds, bass, cellos. Drums have a snap of attck that is quite punchy. At the moment, I'm enjoying the BA modded Earth far better than with the ADA4527-1BRZ. The Moon has been modded as well and will be next to burn-in. First impressions are really liquid mids and solid bass with clear trebles.
Nov 19, 2011 at 2:23 PM Post #1,233 of 1,252
Did output impedance measurements on my Fun today. With a load of 47 ohm I measured output impedance to ~ 5.75 ohm. I wonder how Audio-gd has come up with the specified 1.5 ohm number.
Nov 19, 2011 at 2:29 PM Post #1,234 of 1,252
What you describe is exactly how I would attempt to explain the differences, well done rhythmic_impulse ! The BA cap mod works equally well on the Moon OPA but I will let you discover these changes rather than preface them here. It's all a part of the FUN (pun intended).
It's funny though, loads of folks have resisted doing these mods because they cannot fathom how such a simple tweak could be so beneficial....those that try it find out as you did that there is something to it and it transforms the HDAMs from good to great. I always seem to end up with the cap modded Earth module in the gear that can use one and then forget all about swapping these things out.
I haven't (personally) bothered cap modding a SUN module yet (others have and had good results) since I really don't like OPA's with boosted lows and highs ( a "U" curve so to speak). My preference is to try and remain as faithful to the original track as possible (even if the HDAMs are not exactly true representations of neutral in the classical sense).
Peete.
Nov 19, 2011 at 5:46 PM Post #1,235 of 1,252
Does anyone use the FUN with LCD-2? I'm thinking about buying audezes...
I plugged a set of LCD-2's into my FUN at a head-fi meet.  They ran fine and that's using the sun opamp.
Dec 8, 2011 at 10:55 AM Post #1,236 of 1,252
Try the cap mod on the Earth module ( 1uf PIO of 60V rating or greater across the HDAM's + - PS pins in parallel). That little mod helps deliver what you describe as lacking in the Earth module. I use K42 series PIOs for this job and it's a perfect match. It works equally well on the other 2 module flavors but I find for the A-gd gear (using A-gd HDAMs) the cap modded Earth gives me the most natural presentation of the 3. Of course that's just preference on my part.
The K42's are cheap but work very well.
Peete.
Hi Peete,
I really want to try the cap mod that you mentioned but I am not sure what to do.
Is the K42 PIO refers to the Russian K42-Y2? You said the voltage can be greater, how about uf? must it be 1uf?
And I am not sure what is the HDAM/s + - PS ? Can you show me?
Thanks!!
Dec 12, 2011 at 6:05 PM Post #1,237 of 1,252
Hi Peete,
Thanks!!
There are numbers on the underside of the HDAM right next to the pins to help, you can't miss them.
There are a couple of solder pads right next to and in line with each power pin.  The other solder pad that each stock Evox Rifa film cap is connected to leads to the white ground wire.
Dec 14, 2011 at 7:32 AM Post #1,238 of 1,252
I'm kind of noob when it comes to opas so I need some advices. I ordered  this Dual Opamp Adaptor little too hastily without knowing what kind of AD797BRZ I should order for it.
So I found this single AD797BRZ from ebay and I would need to buy 2 of those for the adaptor, right? Then there is this dual AD797BRZ that do not need any adapter, as it already has one. So should I get 2 single opas for the adapter, or the pre-built dual.  Is there there any differences with those two AD797BRZs in sound quality? Lastly I do not have any extra power source for my Audio-gd FUN and I read somewhere that opas get better with extra power, so can I drive dual AD797BRZ fine without the extra power source?
Dec 14, 2011 at 11:49 AM Post #1,239 of 1,252
If you need AD797B, it does not have PDIP version and so your Dual Opamp adapter is useless. Just go for the pre-soldered dual AD797BRZ. There should be no large difference between the pre-soldered and the DIY one, although some will think the quality of solder and adapter might affect the sound.
Personally, I don't think you need an extra power source for the opamp. I know with a better power source, the opamp should sound better. But if you really do this, you might then need to consider to give an extra power source to the clock and the upgrade list becomes endless........
Dec 23, 2011 at 9:39 AM Post #1,240 of 1,252
Is the K42 PIO refers to the Russian K42-Y2? What about the capacitance (uf)? If I could not find it, is there any suggested alternative?
Then I should connect the CAP to pin 4 and pin 8, then remove the stock MKT, right??
Dec 28, 2011 at 7:20 PM Post #1,241 of 1,252
I think it's the Russian K42-Y2 indeed.  My OPA Sun has a ceramic capacitor, metallized polypropylene film capacitor, and a 10uF tantalum capacitor for bypass.  The tantalum made the biggest change, I suppose that the film cap didn't as much because it's such a small value, lol.  But then those metallized polypropylene film caps quickly become very large (physical dimensions) and expensive if I want larger values.  For the PIO cap, I would go with some value between 2uF and 10uF, I suppose.  That's what I've seen recommended for film bypass caps.  You should also add a 0.1uF ceramic capacitor (C0G/NP0 type).  You can get those from fleabay, Digikey, Mouser, etc.
If you decide to try the tantalum capacitor, beware that it is polar and you need to connect the negative end to pin 4 and the positive to pin 8, otherwise you may damage your equipment.  The capacitor will be labeled to help you.
Apr 9, 2019 at 4:21 AM Post #1,245 of 1,252
One more thing in case anyone missed the post about jumper settings. Instead of using the soft1 2 3 settings to get rid of some of the harshness, change the jumper on the AD1852. There are two possible jumper spots on the module. The one closer to the front is to set it to 192khz upsampling (stock setting) while the pins near the rear are 96khz upsampling. The 96khz is perfect and gets rid of any harshness. Also this way you're not applying any kind of "soft" filtering to your music.
This was posted before but it was kinda confusing to understand what was being said.
I know it's been 9 years, the FUN has been discontinued for 8, nobody has used the FUN for 5 etc... but thanks for the information about the DAC oversampling and such. The DT880 sibilance was borderline painful, and now the KOSS ESP 95/X had some grating sibilance that this has effectively neutralised for me. Now it's time to replace the Burr-Brown 2134 to get rid of this dark flavor and hopefully tame the sibilance a bit more :)
edit: as has been reported previously, it took the edge off but this DAC is inherently sibilant. to be continued...
