[REVIEW] Head-Direct RE0 - a new contender for the best IEM
- Thread starter ClieOS
- Tags
- altec-lansing-inmotion-im716 head-direct-re0-in-ear-headphones head-direct-re1-in-ear-headphones head-direct-re2-in-ear-headphones hifiman in-ear shure-se530-sound-isolating-earphones spider-realvoice-vertical-in-the-ear-headphone ultimate-ears-triple-fi-10-pro-earphones-gun-metal-blue-with-roadie-case
zfmduel
- Mar 5, 2010
in that case try the sony hybrid ($10 in my local sony store) they provide superb isolation and comfortableness
Originally Posted by Sephael /img/forum/go_quote.gif Has anyone tried adding foam or something inside the flanges to improve the isolation ? I've been thinking about doing so, I'm kinda on a search for some tutorials or guides as I recall someone doing it (not sticking foam inside the main "tube" but between that tube and the flanges, as to improve the sealing EDIT: I also remembering seeing stoppers used instead of the flanges (a circular hole inside the stopper for the earphone..) |
TheGame21x
Man, the first time I had that happen was when I was taking off a wool coat on a dry winter day. Boy did I remember to take my earbuds out after that!
Originally Posted by playingwithfire /img/forum/go_quote.gif It's just static. I remember on a especially dry day I actually had the RE0 SHOCK my right ear twice while walking. Boy I was awake afterwards |
bballtime
- Apr 22, 2010
Hm i wear 100% cotton clothing, that must be the source rite
Originally Posted by dfkt /img/forum/go_quote.gif Could be that your clothes are static-electrically charged? I've often have IEMs crackle when I wear a jacket made from synthetic fiber or such. |
b-sides
- Apr 18, 2005
I also get occasional crackling in my RE0s, and I'm starting to wonder if it's the headphones themselves... I have plenty of other higher end headphones that I've used on the same source and equipment, so I'm pretty sure that its not them. Does this mean that theyre damaged, or are they just not shielded well? I've only had them for a week...
RicHSAD
- Jun 29, 2009
Recently got those and I love their sound so far. The only thing I don't like about them is that they are aren't too good comfort wise. Those little notches on the buds seem to irritate my ears after a while.
Royal2000H
- Nov 27, 2009
Try changing the tips. Some tips had the metal part annoying my ear and others didn't.
Right now I'm using the smaller bi-flanges.
By the way, after more hours of listening, the bass really opened up on these. I didn't think such a big diff was possible in an IEM.
Originally Posted by RicHSAD /img/forum/go_quote.gif Recently got those and I love their sound so far. The only thing I don't like about them is that they are aren't too good comfort wise. Those little notches on the buds seem to irritate my ears after a while. |
Aynjell
- Jul 9, 2009
Has anybody found that the RE0 had degraded performance with the newer version? They've undergone many changes and price reductions, and I want a pair but don't want to order a pair if they're not what I've read about.
Hmmm... Have you had the chance to compare a new pair (less than 3 months old) with a year-old pair? I bought mine back more than a year ago, when they first dropped to $99 and had the fabric cable cover -- still sound fantastic after a year.
pxwee5
- May 11, 2010
Hi guys, I just got my RE0 today.
I plugged it straight away in my laptop to test it. But before I could play any song, I noticed that the noise is so apparent there is no way I could say it is negligible.
I tried to play some slow music from "5 Centimeters per second" soundtrack. When the music slows down (low tone), I can hear the noise still "creek-ing" around .. which is extremely annoying.
The earphone did a good job isolating noise from outside (friends chatting etc), but the microphonics is driving me crazy.
Did you guys experienced the same thing or is it just me?
Just into 1 hour of burning now ... so far so good. Sounds better than my Koss KSC75.
And does burning in reduce the noise level?
Sylafari
- Apr 28, 2010
I just got my RE0 a few days ago. No creaking sound, could it just be part of the bad sound in the song? Yes the microphonics aren't that great though.
The noise is probably your sound processing hardware on your laptop. The HP jack on my desktop at work is very noisy -- my daughter's HP is quiet -- just depends on the on-board sound hardware. And the RE0 has a way of making poor stuff sound really bad.
Try using the RE0 on some other source -- CD / MP3 player, etc.
pxwee5
- May 11, 2010
Do you have any idea why the sound processing hardware would produce noise in my laptop?
Any idea how to remove the noise ?
BTW, I will give it a try with other machines and report back =D
chopstixZ
- May 12, 2010
I recently lost a small bi-flange tip and i'm thinking about grabbing a replacement kit from head-direct for $15. There isn't really any other comfortable pair of tips for me in the set with the RE0's i got, so should i go ahead and just purchase the $15 kit from head-direct or should i try out another set of tips (thinking about grabbing sony hybrids). Open to suggestions for tips!
Aynjell
- Jul 9, 2009
First off, try disabling all microphones (muting them is sufficient). In fact, mute everything except for your primary sound. See if that helps!
Secondly, try using a different source. If it doesn't show up elsewhere, then your laptop's audio hardware is like all other integrated audio hardware, just plain terrible.
One sound system impressed me so far, and that was the sound on the Dell Zino HD. The quality and performance was bad, but it actually outputs line out out the back. I was pretty impressed by that!
