Questyle QP2R
post-14645727
Post #661 of 1,073
baiyy1986
United States
United States
It sure is a magnificent device. It’s simple, but sounds so good!
I would say there are four main reasons I choose this device, I like its look; I know it sounds good; It is a solid device, and I love Linux, simple but efficient. Let DAP do DAP thing, which is playing music.
post-14646372
Post #662 of 1,073
514077
Depends on iems. The andromeda is hissy with the Qp2r. The Sony does well with andromedas and other headphones that require a certain independence. I do own both.
What do you mean when you say 'independence'? Just curious.
post-14646387
Post #663 of 1,073
NiVrA
Do you think its worth buying one right now?Im hust worried maybe a new model would come out?
post-14647752
Post #664 of 1,073
neogeosnk
There's always a new model out in the horizon. Buy it if you can find it cheaper than $800.
post-14647996
Post #666 of 1,073
Sale, UK
Sale, UK
Website
audioprimate.blog
Thanks..coming from a hiby R3 would it be a big jump in terms of SQ?
Yes, it is a big upgrade sonically. It has a bigger stage and much more power on hand. The sound is more effortless.
Reactions: PhilW
post-14647999
Post #667 of 1,073
NiVrA
even though Im only using BGVP DMG? I know its not the TOTL but would it be still a big difference to warrant the purchase/upgrade?
post-14648021
Post #668 of 1,073
subguy812
Reviewer: Audio Rabbit Hole
House of the Rising Sun
I would always recommend someone upgrades their IEM first, then DAP, then cables. The QP2R is a serious upgrade, but I would still do first things first. What are you trying to achieve?
post-14648047
Post #669 of 1,073
NiVrA
what do you think is best at the $500 range iem?
post-14649980
Post #670 of 1,073
Spie1904
Belgium
Belgium
I should probably place this in the recommendations thread but do you think the QP2R is currently still one of the 'best' DAP's out there for 'One DAP to rule them all' purpose if you like. I'd be using it with either Campfire Audio Cascades or Andromeda's. But my concerns are mostly that I can't stream on it and I'm a bit afraid of the storage as my goal would be to discover music on Spotify and eventually buy the high quality songs to put them on my DAP later on (QP2R seems low on storage for that purpose) :)
post-14650013
Post #671 of 1,073
AmusedToD
QP2R is a fantastic sounding DAP, no doubt about that. I use it with the Focal Utopia and there is special synergy with that pairing.
The downside is it’s lack of streaming capabilities.
Regarding storage, I am using a SanDisk Ultra 400GB MicroSD card and it performs flawlessly.
post-14650021
Post #672 of 1,073
Spie1904
Belgium
Belgium
Thanks, I was thinking of getting a Q2PR + SXC ALO 8 balanced cable for my Cascade.
The only thing I hadn't worked out yet was whether I should get the Q2PR or the Ibasso DX200.
The Ibasso DX200 I can already get for about 839 euro and has streaming options whereas the Q2PR costs 1300 euro and no streaming :p
post-14650683
Post #674 of 1,073
t69p
