It’s Rimiwa from Thai Airways.What is that yellow case ?
& Congratulations for your purchase.
Questyle QP2R
- Thread starter unknownguardian
Store QP1/2R face down.
Thought I would share this. I bought a 2nd hand QP2R which had a frozen scroll wheel. It was so tight that even 2 fingers could not easily move it.
I added a DIY silicon ring, and it became workable, with some effort. Only worth using for changing settings, etc. Otherwise it was easier to use the touch controls.
I got the QP2R for a lower price because of the frozen scroll wheel, so I cannot complain, but it made me look for some way to lubricate the scroll wheel. In the end, it would have required a disassembly of the DAP, so I put the thought away.
I had put it away on a plexiglass rack, face down (top end angled higher than the bottom end) for a couple of weeks, following advice on this forum, to prevent dust from getting into the scroll wheel, and making it tight.
So I took it out today to test 2 DDHiFi (DJ44B/DJ44C) adapters I had just received.
Consider my total surprise to try the scroll wheel and find that it was working normally! Easy to turn with my DIY silicon ring!
I am guessing that storing it face down allows the factory lubrication to flow to the bearings, and lubricate them, while using/storing it face up may be draining the lubricant away from the bearings.
So a simple habit of storing the DAP face down, can help to keep the scroll wheel working normally!
EDIT: Putting it face down, and on High Gain/Bias and using the balanced 2.5 mm output warms up the player, and may help to redistribute the oil.
nickipedia
Wow that's one very unique & logical advice for anyone having trouble with wheel ..Store QP1/2R face down.
I have a rather particular question to ask you... I own both the QP2R and the M15 but I can't understand which of the two has more powerful amplification and by how much compared to the other. Thank you.
Does anyone have the firmware v 1.05 update? I couldn't find it on Questyle's website anymore. I'm getting a new QP2R today and would like to update the firmware before changing the settings.
It's still here on the website: https://www.questyle.com/language/en/dowmloads/
Specifically here is the link: https://questyle-en.oss-us-west-1.aliyuncs.com/Driver/QP2R_1.0.5.zip
Stay updated on Questyle Audio Engineering at their sponsor profile on Head-Fi.
Kozwoz
- Nov 26, 2014
Has anyone ever been able to connect a lightning port iPhone to their QP2R in DAC mode?
I’m getting a message on my iPhone saying saying unable to connect because the QP2R requires too much power. I’m guessing because the QP2R is trying to simultaneously charge from the iPhone. Please let me know if someone has got this to work? The cable are not an issue, the usb-c to lightning is certified and works with other dongles such as the Mojo 2.
There's no option for the user to select digital filters on the QP2R; which digital filter, if any, does it apply?
I can't seem to fast forward or rewing a song on my QP2R. Is there a setting I should turn on/off? I tried to look but couldn't find the right one on settings.
I don't think that's possible. You can only step from track to track, using either the mechanical navigation buttons on the side, or the capacitive left/right buttons. You can fast forward, or fast rewind, by pressing and holding either of the capacitive buttons, but this operates from track to track, not within an individual track.I can't seem to fast forward or rewing a song on my QP2R. Is there a setting I should turn on/off? I tried to look but couldn't find the right one on settings.
