Questyle QP2R
post-14577110
Post #631 of 1,072
neogeosnk
I've been trying to burn in the QP2R and it stops playing after 8 hours or so. Has anyone experienced this while burning in? I turned off the settings to sleep or shut off but the tracks just stop playing after about 8 hours. I want to put about 200 hours on it before doing some critical listening.
post-14577135
Post #632 of 1,072
subguy812
Reviewer: Audio Rabbit Hole
House of the Rising Sun
I did not burn mine in as such, but I would say just listen and enjoy it.
Reactions: Ryokan and oscarnr
post-14577997
Post #633 of 1,072
NehPets
It needs recharging. Depending on what type of files you're playing, the gain setting and the bias mode, battery life is anywhere between 5 and 10 hours. The QP2R doesn't charge and play at the same time, so even if you have the charger connected, it'll only play from the battery. If you intend setting the player aside to burn-in for 200 hours, that'll be an arduous task because a full recharge takes about 5 hours and you'll need to do that a couple of dozen times ...
Reactions: 514077
post-14578371
Post #634 of 1,072
514077
And you'll certainly put a s**tload of wasted charge cycles on your batteries with no apparent enjoyment of the unit. The previous QP1R is supposed to take anywhere from 10-30 hours for initial major burn-in. After that, it's just gravy. Put the thing on and use it and burn in with it.
Reactions: Quadfather
post-14578553
Post #635 of 1,072
neogeosnk
The Qp2r does charge and and play at the same time so I don’t think the battery is affected.
post-14583924
Post #636 of 1,072
cytoSiN
USA
USA
Hey guys...I'm having issues with a brand new QP2R...right out of the box, it won't turn on. Plug it in, and I can get it to show the CMA logo and the Questyle logo (with some Chinese characters over it that I think says something along the lines of "battery exhausted"), and then it just shows the flashing 1% battery image before shutting off, even when plugged in. Left it plugged in all night, same issues this morning after trying to charge for several hours. Tried several different cables and plugs. Any thoughts/advice appreciated. Thanks!
post-14584555
Post #637 of 1,072
neogeosnk
Update on my burn-in issue. Looks like the device has an 80 file limit then it stops. I limited the songlist to 12 and so far so good, burning in like a champ.
post-14584561
Post #638 of 1,072
neogeosnk
Did you try a different power cable and adapter? Sometimes they go bad.
post-14584562
Post #639 of 1,072
cytoSiN
USA
USA
Yes. 5 different cables, all of which work with my phone, and 3 different power bricks from different manufacturers, all rated appropriately for the QP2R and all working with other devices. I've also been searching around and I'm sort of shocked I can't find ANYONE else having the same issue.
post-14584577
Post #640 of 1,072
514077
There's the obvious answer: You might have a defective unit. Perhaps, exchange it for a replacement?
post-14584659
Post #641 of 1,072
cytoSiN
USA
USA
Yup, probably right, but I was holding out hope someone here had a similar experience and a way to fix it.
post-14584774
Post #642 of 1,072
rollinbr
Arizona
Arizona
In the beginning sometimes I would have a hard time getting my QP2R to charge. The USB type C plug is a "really" snug fit in the QP2R. I had to really push hard on the connector to get it to fully seat on the QP2R. Just an idea that perhaps your not getting a full seating of the USB typc C plug in the QP2R.
post-14587750
Post #643 of 1,072
NehPets
You're absolutely right of course, I've run mine off an external battery pack before; can't imagine what made me think you couldn't charge and play at the same time. Ah well ...
post-14587917
Post #644 of 1,072
neogeosnk
Someone posted that I couldn't... never heard of that before with any dap. Just an fyi, if you are burning in: There is an 80 song limit before the player gives up and stops playing, use a shorter playlist. Also for screen protector, I got a piece of an old water based ipad mini screen protector, put the plastic screen protector on the skin, drew out the shape and cut with x-acto knife. Fit perfectly and now no bubbles and looks amazing. For case I custom ordered one from Valentinum on etzy. He has the best custom dap cases.
