Chris Ihao
- Dec 23, 2010
you might wanna check ebay periodically, might find a seller who ships internationally?
Yeah. That is a possibility. If not I can buy the original pads here in Norway, at approximately the same cost as on amazon.
Edit: Cool. Found some cheap g cushions produced in China, priced at 25 usd with free shipping (!!!). I highly doubt that the material differs that much, and even if it does, its really no risk. Thanks man! Didn't even consider the bay, as I haven't been there for ages. My stock cushions are a bit shabby, since the model I bought have been used for demo purposes. The sound is brilliant though, is covered by warranty for several years and is basically only a bit burnt in. Anyways; Ordered!
