@zombywoof, if you are ever looking for cups again try: http://www.rholupat.com/products?page=2
They also have gimbals, leather headband and rod blocks
Just finished building 2 headphones over the weekend, one with the Symphones Magnum V7 drivers and the other with Nhoord red drivers. A very simple affair, easily the most time consuming portion is the braiding of the cable.
I bought the headphones frames from Taobao and it comes fully assembled. The wood are South Africa Ebony and Rosewood. Each frame is about $100 shipped to Singapore, and come with 2 different set of pads, 3M grills and pads which I didn't use.
The cups are screwed together, with SMC connectors, so it's a simple matter to unscrew the cups, attached the drivers to the cup lids with double-sided mounting tapes (because the drivers are slightly smaller than the lids), solder the connecting wires to the drivers and screw back the lid. At this point, your headphone portion is basically done.
Here they are with the balanced cables attached. I used silver plated wires terminated in 4 pole XLR plugs.
Nice work! Don't leave us hanging here: how do they sound?!
Edit: what amp are you using?
Are these impressions based on both drivers in the same wood housing or on the two different wood types? I know my ypsilon driver and SR-225i/e drivers sound quite different in the rosewood versus the walnut cups and the style/shape of the cup also makes a difference.
These are different wood types, same cup shapes. The magnum is in south africa ebony, the nhoord is in rosewood.
Since the design of the cups you are using are quite different from the ones I use its hard to say how much the wood type will account for the final sound so I'll take your word.
With the cups that I've been using where the driver is press fit in the cup the type of wood makes quite a difference, I would guess 10-25% if I had to put a number to it, hope anyone else reading this thread would chime in with their opinions on the effect of the wood types on the sound along with their mounting style and its effects.
@xuan87, Really appreciate your taking the time to post your impressions.
Ahhh ok, that's one part where our design differ then. Mine are mounted into the cups with a layer of double-sided mounting tape which should serve to dampen to some degree any vibration from the drivers.
