I have started.
Have ordered a Headband from Turbulent Labs (thanks liquidzoo for the headsup).
Then from plusSound I ordered a Cryo Treated 3.5mm 1/8" Rhodium Plated Straight Plug and their Cryo Treated Aluminum Y-Splitter.
From there I am going to use the Grado cable and re-cable it all, by Litz 8 Braid. Now this is where I'm having trouble. I need to know what the size of the conductors are in the Grado Cable without cutting it to bits first.
Reason being, is I want to find either TechFlex and/or paracord, to cover each and everyone of the 8 conductors. I will 8 Braid to the 'Y' then 4 Braid to the drivers.
Can anyone suggest what size paracord and tech flex I should get measured at the ID (inside diameter) ??
And the pièce de résistance. . . . . I hope to be doing business with 7keys on a nice set of cups.
will post as I start modding, but would like feedback on the conductor issue, so I don't have loose fitting over them when I braid them up . .
