wolfetan44
- Mar 27, 2012
Is it easy to install a female 3.5mm? Does it have the same basic layout as a male 3.5mm?
That should work. I'm not sure about the quality of that particular connector from Radio Shack. However, if you do use it, apply some super glue on the inside of your cup to assist with holding it in place.
Thanks for the quick answer! Yeah I am more just trying to test the waters with this connector, if it works and I like it I will probably upgrade it at some point. Good tip with the super glue as well!
It looks to be an even easier solder job than the male plug, as there are not as many space constraints. Very simple!
I actually just finished it up, and I went the single-side route using the TRS connector, so it is now detachable stereo from the right ear cup. I just ran a connection through the headband.
Since you're doing mono plugs, shouldn't you have the plugs on both sides? Or am I wrong?
Quote:Since you're doing mono plugs, shouldn't you have the plugs on both sides? Or am I wrong?
Nope, I actually did a stereo plug. The wire you see running over the top where the new headband will (someday) be bridges the left driver to the connector. For mono plugs, you would need one on each side though.
You are exactly right!! My idiot brain confused mono with stereo. Wow, I will edit that now! Nice catch
Haha! What glue did you use also?
Quote:Haha! What glue did you use also?
This connector actually came with a screw-on ring, and that plus the overlap of the outer cup holds the connector in place quite nicely. If your connector doesn't have this, however, I have seen superglue used quite effectively. wje above recommended the same thing.
