post your grado mods....
Jun 3, 2008 at 7:48 AM Post #361 of 8,992
So far just HD414 reverse pads and new mesh. I made the mesh a bit convex for better appearance.
Jun 3, 2008 at 5:30 PM Post #362 of 8,992
In your opinion, how do the reversed 414s compare to the bowls?
Jun 3, 2008 at 5:32 PM Post #363 of 8,992
You are really getting there! You still planning the great "removable cable" mod?
Jun 3, 2008 at 5:35 PM Post #364 of 8,992
I can tell you that I am not a fan of the Senn pads. I have had five pads and can rank them (personal preferences) like this for you:
Sr60, 80, 225:
1. bowl
2. flat
3. Senn
4. Radioshack
5. Comfie
SR325:
1. Radioshack
2. Flat
3. Comfie
4. Bowl
5. Senn
Jun 3, 2008 at 5:52 PM Post #365 of 8,992
Are the flats a different foam texture to the bowls?
Sr60, 80, 225:
1. bowl
2. flat
3. Senn
4. Radioshack
5. Comfie
SR325:
1. Radioshack
2. Flat
3. Comfie
4. Bowl
5. Senn
Jun 3, 2008 at 6:05 PM Post #366 of 8,992
They seemed a little stiffer, but I didn't keep them very long. They might loosen up.
Jun 3, 2008 at 8:36 PM Post #367 of 8,992
I've never tried the bowls but I do prefer the Senns over the original pads.
Of course. I want to do my first cMoy first then I'll start messing with cables. Probably do a Canare Starquad interconnect then recable these guys.
Jun 4, 2008 at 2:39 AM Post #368 of 8,992
@juniperlater: can you link me to the radioshack pads? I can't seem to find them.
Jun 4, 2008 at 2:54 AM Post #370 of 8,992
I need to head over to radioshack and do that radioshack mod. Looks so nice.
@jonjon, sure give me some time and I will post pics. I got the mesh from a member here. Got really lucky in that. He had a FS thread up for the longest time...I really liked to look of it in his pics. A pm and I got a set. Great guy,
Jun 4, 2008 at 3:57 AM Post #372 of 8,992
The radioshack pads are ok in a pinch, but they aren't thick enough to fit all the way onto the housings.
My favorite is the Senn 414 pads, since they are stiffer than comfies so they don't vibrate and make the bass muddy. They are basically like bowls that are comfortable.
Jun 8, 2008 at 12:10 PM Post #374 of 8,992
question... sorry. it's just so hard to search for stuff on head-fi...
i'm looking at the senn hd414 pads for my sr80's and i'm wondering if they are that much more comfortable. the sr80 pads really give my ears a beating after about an hour. or is there any other pad that you guys would recommend?
and if anyone could point me in the direction of where to get those cloth-type cables for a recabling diy, that would be awesome. thanks a bunch
i seriously cant find anything on head-fi...
pm me pls... i dont check head-fi that often
Jun 11, 2008 at 10:42 PM Post #375 of 8,992
Okey woops. I posted earlier about the glue I used for my grill mod. I used 'secondelijm' in Dutch. It's the glue that sticks in only 1-2 seconds and produces a nasty gas that even colours my plastic cups! Well, opening is a certain nono atm. What to do?! I can't get acetone there since the glue is inside the cup..
