DefectiveAudioComponent
- Jan 20, 2008
Sorry for the derailment of the nice HE5 discussion....
I have taken the PMB-80 apart and done a stage 1 damping on it. Well, almost, the pads aren't so well attached to the baffle yet because I misplaced a piece.
It had that great foam damping that also the Grundig had, but more of it. The foam was crumbling and had to go. Instead, I put yellow fiber glass for isolating ventilation pipes inside. I kept the woven material on the back of it for now. Bass is happier now. Drivers are happier now that the crumbling foam is on the outside. I am happier now that it sounds good. Something might be missing in the top end, but I am used to the sparkly LCD-1. Maybe some pad rolling could be fun. Or a reflex dot.
It's bascially a good headset. Open-back, circum design. The grille has maybe too broad bars, so maybe it only counts as half-open.
The drivers look even nicer in reality than on the pictures. Large holes in the magnets, and lot's of them.
EDIT: One driver went all silent on me. Maybe there is also a hole in the driver then.
