Orthodynamic Roundup
Oct 19, 2009 at 3:01 PM Post #12,136 of 27,185
I got inspired by the egg-mod and decided to make a bass-heavy ortho out of the Dual. (Since I already have the light and airy LCD1)
I put on the thin comfy lambskin pads, and redid the damping. Out went all felt, the disc in the back (converting it to open-back), etc.
I decided to only use one thick piece of fiberglass as damping. But since I am only using that one piece, I decided not to use the normal kind of yellow fiberglass for wall isolation. I instead picked a piece that's a bit stiffer but also supposedly damps harder.
Initial listening through my pioneer power amp says its got plenty of (deep) bass.
Oct 19, 2009 at 3:11 PM Post #12,138 of 27,185
I try not to do movie references, but it's from Cameron's Titanic.
Sounds like you west coast guys are going to have a good testing session that will include the new orthos from Audeze and Head-Direct. Brush up your damping. Give those oldsters a fighting chance.
Oct 19, 2009 at 3:21 PM Post #12,139 of 27,185
Poseidon probably slipped back into the freezing waters of the north Atlantic with a smile on his face after wrecking the Titanic.
Of course I would prefer the older orthos to be able to keep up with the newer ones (my wallet would very much agree) but in my biased opinion, the old orthos don't hold a candle to the new ones, just based on design and specifications alone. The size of the drivers, better tolerances, better magnets, open back, etc etc.
Oct 19, 2009 at 9:54 PM Post #12,140 of 27,185
No, and I wouldn't really expect them to. They were well and truly hobbled by their makers in many ways, most likely to get costs down. All I ever expected was that they'd point the way and show a family resemblance to the new stuff. 80% of the quality for 10% of the money, or close to that.
Back to SFI's a moment. Someone was asking about them, and while I think both 120-ohm and 32-ohm versions can be useful (depending on what you're using to drive them), the 32-ohm version seems to mate best with home amps and many if not most portable amps-- obviously your mileage may not only vary but depart from all expectation. The simplest homebrew enclosure is a ported Smeggipuck (my whimsical name for it), illustrated here.. The tiny port leads directly to the edge of the felt disc(s) which lie behind the driver. Your burden, should you decide to assume it, is to find a way to attach these pucks to some sort of headband, maybe like the one illustrated here, which is either an old ATH-3 or ATH-5 but could also be a Signet TK22.
It would also be interesting to transplant an SFI into an ATH-2, or use the ATH-2 open-back design to modify a SmeggiPuck.
Oct 20, 2009 at 6:44 AM Post #12,143 of 27,185
"Lost After Konichiwa" would be a great song for The Flaming Lips.
I'm still hoping that Fostex has a skonk works next-gen isodynamic program going somewhere deep in the hive, just as Mazda had an unauthorized clot of fanatics working on the side-port Wankel.
Oct 20, 2009 at 4:02 PM Post #12,144 of 27,185
First let me thank everyone for the suggestions on fixing my head-strap.
As suggested my local shoe repair guy was intrigued when I contacted him, a few days later the custom leather he order arrived and he replicated the head-strap for me in black, a little slippery but in some way better than original.
The ear pads are permanently compressed at this point and in need of replacement, any suggestions on a direct replacement and where to buy them. I did surf the hi-fi site but no clear recommendation.
Last but very important, one of the ball joints broke off a couple of days after replacing the head strap, probably jealous and in need of attention. First attempt at gluing it failed miserably with epoxy. Any suggestions on repair or replacement, for that matter any suggestions on extracting the post from the sling press fit?
Again, THANKS!
Mark
PS If someone has a flamed out pair of YH100 they want to sell for parts let me know.
Oct 20, 2009 at 4:13 PM Post #12,145 of 27,185
Found post on ear pads, thanks Boilermaker
http://www.head-fi.org/forums/5928841-post11478.html
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx
"In the case of rythmndevil's YH-100s, a $5 Koss R10 ear pad proved to be the most consistent even over ESW9 leather ear pads when swapping systems. I had the YH-100s tuned to a spectacular level for my CR-620 with the ESW9 pads, but when I switched to my old receiver and the PC, the bass was gone and the highs were painfully bright. The SR-X pads were the same way, if not even worse. Back to the R10s, a little tweak to the tape on the back of the driver and they were very consistent across the 4 systems and at a level that I would call 90-95% of their capabilities in the stock headband cups. The last 5-10% can only be extracted by rd tuning or tweaking them on the specific gear rd plans to use to his tastes."
Again, THANKS!
Mark
Oct 20, 2009 at 6:22 PM Post #12,146 of 27,185
Again, THANKS!
Mark
Which side do you need replaced? I have a YH-100 frame with one cracked strut and one good one. I forget at this point which one is cracked.
Oct 20, 2009 at 7:51 PM Post #12,147 of 27,185
Open back... well, half-open back at least wasn't that uncommon (Dual, Akai, Grundig, PMB...) and it can give decent headstage.
Oct 20, 2009 at 10:43 PM Post #12,148 of 27,185
In Europe, sure. Here in the US we're pretty much limited to Yamaha and Fostex, with a couple oddballs here and there (correct me if I'm wrong, I haven't been actively searching in a long time).
Oct 20, 2009 at 11:25 PM Post #12,149 of 27,185
EricJ,
The right side headphone ball joint is the one that is broken, L & R appear to be the same to me.
Any suggestion on how to disconnect the press fit from the sling? Just push the pin out, is it that easy?
Once I get it torn apart, I might as well rebuild the padding and look at changing the wires while the patient is open.
Thanks
Oct 21, 2009 at 3:06 AM Post #12,150 of 27,185
Heh..am having a ball with all the ortho goodness that I have currently at my disposal..at least for the next couple of weeks.
Look at what's happening here..an ortho orgy...picking on the lonely stat
