- Mar 30, 2007
I am inclined to advise you with the latest T50 trend. How are the pads? Are the sealing? And how is the hole? Does it block any of the baffle grille?
Depending on your answers, Id say go with getting very sealing circumaural pads, BUT only one with a holes thats just ear sized, not a large cavern like a K240 or beyerpads (which will just make a muddy mess of everything).
This will make sure you retain as much deep bass as possible. And by furthering your ear from the driver with this small chamber you should slightly tame the midrange and bring out the trebles. (you might also find that if you do this and its succesful, that going with fairly light damping is the best bet)
