My new find. Just bought them.![]()
It seems to be like audio-technica’s ortho!
Wonderful
you need to peek into the driver and check for the magnet disc with holes in it in circlesHow do you know please they are orthodynamic headphones?
Thanks a lot for your picture! I bought these headphones for myself too last week.you need to peek into the driver and check for the magnet disc with holes in it in circles
there is a mesh sheet in front of the driver so it is pretty damn hard to take a good picture to help you out
there is plenty of details about these rectangular shaped headphones in this thread
I dont know but that's a good link. Is it yours @Feilong4 ?Hi! I‘m new to the forum and came here because I found some Yamaha Hp50a in the trash which still work fine. I browsed the forum for the last 2 hours on my search on a stereo mod tutorial. I found this one online https://orronoco.blogspot.com/2021/06/under-radar-stereo-re-cabling-for.html?m=1.
I have soldering experience, but have no experience with headphones at all and find the tutorial very confusing. Is there another one for similar headphones?
My
Fostex T30 has a L/R channel imbalance. I dont know the cause, perhaps damaged during shipping. I resoldered connections but seemingly not the fault. Unless someone wants then I will keep as a souvenir. @VanHai gets first dibs if he likes since he sold me T30 for cheap.Sounds better than I remember. I forgot how comfortable the headband is, and forgot the YH-1 pads feel less comfy than YH-2 due to weight. I could imagine sacrificing bigger driver bass for weight comfort reasons. Might get YH2 as well as I always preferred.I bought a Yamaha YH-1 for old times sake.
- squashed L<>R soundstage, despite that imaging is very clear and well defined
- microdetail curiously seemingly not far from HE6se. I suspect environment noise isolation (closed cups / pads) helps Yamaha in hearing fine detail (low noise floor)
- crunchy guitars like Grado, upfront and detailed guitars and vocals, perhaps partly an effect of relatively dimmed cymbals amplitude (tapering down highs) and few db extra at 1-2kHz. I suspect the tapered highs keep Yamaha from sounding as microdetailed and microdynamic as HE6se
- bass is tuneful, well extended, bass sounds impactful but probably very slight reverb or bloom that is causing some perception of bass weight, was expecting less bass amplitude and impact.
Simply opening the cups results in changes in the sound due to old stale foam becoming dislodged. Would like to restore to original.
I could never tune these satisfactorily. Always a trade off. Same with T50RP.
Completed testing for now. Tried subtly breaking seal with one of those headphone earpads socks. The result was too much warmth, decreased bass extension, and loosened imaging, impact, definition. Because combination of lightened driver damping and diminished highs relative to increase in bass?Will update when completed testing but probably not soon
Monoprice AMT inbound
The socks did improve comfort!
Next might be to try some dense flat foam donut pads (e.g. grado f-pads). No longer confident in potential but still curious. Will start by just placing foam pads over stock flat pleathers.
This is very big news for this thread; the first time a really major mainstream company is producing planars in volume. Something which was of interest in this thread a decade ago. Fingers crossed it leads onto better things in terms of mainstream planars.Sooooo Audeze were bought by Sony, and now Sony have announced these:
For the playstation based on Audeze tech as far as i can tell.
Anyone think they will have a chance of being good? They are quite cheap(both for a ANC headset and compared to Audeze products) at only $150 but it seems quite unclear if they will work without some propriatary Sony basestation thing
It describes using T60RP drivers because they are better. Im guessing T60RP are better only due to quality control where the drivers are personally visually inspected by a human.Fostex T50 50th Anniversary.
