nick n
- Feb 3, 2011
ATH-1 ^^^
oh nice. So you are liking the magic Sponge.
I think those actually look cooler than the 2's.
yeah that will be an SFI.
but there are a few different ones around.
Different housings ( plastic clamping housings, metal clamped housings ), ohms, front/rear dust cover material ( fabric, fine metal meshes ) spacers ( perhaps ) even ones with more holes per side or similar ( IIRC )
Pro30 is an SFI for instance and can get going quite well in the bass department right off the bat vs some of the others.
The Technics 63ohm versions have generally seemed less bassy in my experience ( which could be case specific )
It's been a while so I am unsure if AT ever made their own at all or Sawafuji was the OEM always.
Anyone?
Did i totally screw up that info?
So they call it a FLAT DRIVE.
~N
Anyone?
- 20 -20,000 hz
- Allowable input 1000 mW ( 1 minute continuous )
- Sensitivity 93 dB / mW @ 1kHz
- low-noise Y type soft cord
- weight 190 grams including cord / 145 grams without cord
- released around 1978, end of production around 1981
~N
