Dyaems
- Mar 25, 2011
I haven't changed the dampening yet, but with the velour + 1 layer of arctic cotton, the headphones are noticeably bright. Also its brightness is in the border of being sibilant. It will create that sssSS sound then it will suddenly stop. I think the short sibilance depends with the setup though, because I don't hear the same thing with my desktop setup ("super" cmoy/arrow 4g and modded creative CT4760 soundcard) while it is there when i use my portable setup (sony F800 and headstage arrow) Also, treble abit sounds grainy and less crisp compared to the previous frame using the Acoustipack foam which I liked the treble coming out from it. Midrange is still sweet and lush, just i remembered when I used it in the other frame. Bass is present but i think it needs more impact, bass body is clearly there and more than enough for my needs. Imaging is great, just like how i remember how it sounds when the driver is in the previous frame.
Also, It sounds abit veiled straight from a DAP even at max volume, so amping it really helps.
EDIT: Poweramp App is causing the sibilance for some reason, i tried the stock walkman app and jetaudio app and i did not hear it there. =/
They look great, and the drivers look like they were placed stock from the store
I never thought about the HD25 pads always assumed they were too small for stuff but they look good actually, even the velour is tempting. Could you let me know what the outer and inner measurements are for those pads if you get a chance.
Thanks for posting all that. Tell us how they sound after you rest up. Looks like a lot of work already.
one layer of that stuff either pressed to the cup back with thin foam or against the driver with thin foam may be enough, I recall taking most of it out of a few that I used more than 1 layer in. The bamboo crud is a little thinner though.
