Dec 12, 2012 at 8:25 AM Post #20,866 of 27,306
I would not mind any variations in the acoustic front in the mm region, because the wavelenght of 20kHz is 1.7cm. As long as there is no disturbance or any obstacle to the free flow this should have a neglectible influence.
Dec 12, 2012 at 7:14 PM Post #20,867 of 27,306
Off topic, but this does represent another way to move air and thus another way to produce sound, aside from the cooling function.
http://www.genewscenter.com/Press-Releases/GE-Cooling-Technology-As-Thin-As-A-Credit-Card-Enables-Ultra-thin-Tablets-Laptops-3cf6.aspx
And once again it's look-ma-no-magnets, piezo to the rescue.
Dec 12, 2012 at 9:00 PM Post #20,868 of 27,306
"The turbulent air flow of the DCJ increases the heat transfer rate to more than ten times that of natural convection."
I wonder to how many times that of natural convection a fan increases the heat transfer rate. 100?
Dec 12, 2012 at 10:23 PM Post #20,869 of 27,306
I suppose the air-motion-transformer/Heil speakers are somewhat related... http://en.wikipedia.org/wiki/Air_Motion_Transformer
Dec 13, 2012 at 2:20 AM Post #20,870 of 27,306
This appears to be a ducted piezo fan, and the blade simply waves back and forth at high speed, so it doesn't look like it makes use of the "clapping" motion of the Heil invention, although no reason why it couldn't down the road.
Air motion in the piezo fan is from the high-speed vortices (miniature tornados) being shed from the leading edge.  Make a headphone out of it and you could give it a cool name like VortexaPhone. The engineering problem is figuring out how to modulate what in electrical terms would be a noisy DC power source.
Here's a Boeing patent that may or may not be of interest: http://www.google.com/patents/US4834619
Dec 15, 2012 at 8:18 AM Post #20,872 of 27,306
update to the HP-1 mods:
new earpads made of fine goatskin with visco foam:
made the hole smaller than the original (for comparison on the left side of the picture) and got a better seal to the ears and the sound is more involving and direct - like it very much!
Dec 15, 2012 at 11:06 AM Post #20,873 of 27,306
Got down to it and fixed my Grundigs this cold Saturday. Basically copied Ludoo's and gurubhai's damping scheme, very simple.
In its present state the GDHS223 sounded bland and lifeless, no doubt because the only damping, a foam disc, had turned into goo and crumbles.
First a clean-up to get rid of all the debris.
Then a disc of felt (Ludoo's 1 mm Brookmore wool).
A similarly shaped piece of foam.
Some double sided tape.
And finally another pice of foam, I used two layers since the foam was quite thin, and some blutak on the baffle for mass damping.
Initial results are very promising - it sounds excellent and goes to show what a little damping can do. It's balanced throughout the frequency range with good dynamics and air too. Will leave it like this for a while to let it settle before I decide if further steps might be beneficial. Cleaned the rest of the headphone as well - the pads and headband were in quite good condition and it's very comfortable to wear.
Dec 15, 2012 at 12:22 PM Post #20,874 of 27,306
At first I thought you were going to be using hair for damping... then I realized it was just a picture underneath.
So while we're on the topic of weird, has anyone tried hair? After all... it's thin, organic, a good insulator...
Dec 15, 2012 at 3:54 PM Post #20,875 of 27,306
So while we're on the topic of weird, has anyone tried hair? After all... it's thin, organic, a good insulator... :rolleyes:
Haha, glad I'm not the only one that thought that.
Hair? I'm sure having hair sticking out of vents will not look appealing :o
Dec 17, 2012 at 7:16 PM Post #20,877 of 27,306
I'll just throw this in here and come back to check after my exams:
Would anyone be able to teach me how to take these apart? I don't know how to remove the driver unit from the cups and these need a complete recabling otherwise unusable =/
It's one of those non-foldable TDS-15. The drivers and cups should be identical to the folding variant.
Dec 17, 2012 at 9:20 PM Post #20,878 of 27,306
Dec 17, 2012 at 11:37 PM Post #20,879 of 27,306
Yeah it should be the lighting. The stuff between the plates are none other than the diaphragm, whose detail cannot be seen due to poor lighting conditions in the picture.
This view = the one on the left in the first link you posted. Magnets seem to be on the back side (right one in the picture). The magnets on this side are parallel to the metal plate
Though from that picture it doesn't seem like the back side would help me much in soldering, except to fit new cables.
:S I'll worry about this in 2 days.
*edited for corrections*
Dec 22, 2012 at 10:55 PM Post #20,880 of 27,306
Wow. Well, nick was Nick was right again. I thought there could be no foam inside the earpads but I was wrong. But what matter of state is that?! Worse then my HP-2 for sure. For now I managed to scrape all of it out and put some foam cutout I had from before.
Recabling also went well but as you can see I really didn't do these justice with the random cables from a Sony I had lying around. Maybe I'll grab a black sharpie and make it look a bit more normal. Not to mention there is no knot or anything inside to keep cable tug from breaking something :S
Because the cups are still cracked I guess, the baffle/pads still do not stay put. The left side of headband is still broken but they're still usable as-is. Assuming I wouldn't be moving too much I'd assume.
**EDIT**
Fixed the mobile auto-correct lol
