vid
- Jan 5, 2005
The damping triad that I now seem to be using for the HP-50S.
Black is polyester, the other two are synthetic felt of the kind they sold me at a crafts store. Each disc is about the size of the driver in diameter. By not damping the entire diameter of the cup, I've tried to keep at least a little bit of soundstage. (The yellow felt in the picture has its hole a bit off-center, but the disc that's in the phones is a bit more symmetrical.)
Some relative thicknesses.
Texture of the polyester disc. The other side has a regular knit pattern but the backside (here) is rough.
Texture of the felt. The yellow felt is about the same, only thicker.
I stuff three polyester discs into the left cup; and the two felt discs go into the right cup. Nothing else, no foam. The driver is blu-tacked onto the baffle and the stock white paper disc is gone.
The raw frequency response is like so.
The channel balance is reasonably good. The spikes around 80 Hz are noise that my recording equipment picks up.
This was the stock raw response and channel balance.
The modded channel balance is better, and of course the response is as well. Both stock and modded, the right channel is about 2 dB louder overall than the left, though, but that's not too bad.
There's some room to mess around with a reflex dot since the treble is a little bit withdrawn, but I figure I might as well adjust that via EQ if I need it.
The sound is neat.
The sound is neat.
