gurubhai
- Jan 3, 2009
yep
The NADs are slightly more difficult to drive than LCD-2 which is odd since the published sensitivity specs would suggest the reverse.
Is it possible that the old magnets have been loosing some of their 'oomph' over time ?
I need bigger diaphragms
What do the magnets look like? AFIK only alnico magnets lose their strength over time but I think those are actually a different color from the normal ferrites.
What shape are the rest of the 'phones in? Any kind of magnet can lose its strength if subjected to repeated and severe shocks, but I'd imagine anything strong enough to do that would wreck the rest of the headphone.
Its also possible that someone may have managed to partially degauss it at some point. Do you happen to store them on top of a CRT monitor? Or maybe the last guy who owned them did.
Basically there are a lot of things that could have happened to something that old and its hard to say what, if anything, actually did.
Nah, nothing like that. They only sound less efficient because they are so bass heavy and with a 30 year old stock cable, corrosion is setting in so the cable has more resistance than when it was new. The specs are from when the headphones were new. Replace the cable and they be more efficient, but then after damping them to cure the errors of their ways they are back to less efficient... but I think they are a little more current hungry than LCD-2s too.
I thought more of the sheer diaphragm mass which makes it moving slower. I guess those PRaT disadvantages and the propably complicated production and QC routines were the main reasons they've ceased building such monsters.
Maybe that effect gets a bit compensated with better pads, but right now, with T20 pads, that NAD is one of the slowest cans I ever experienced. But as we all know, that presentation has a beauty of its own...
Thank you!!
One reason why I want mine to be the bassy one is that I can eventually equip it with super comfortable W11 pads then, I have enough supraaural orthos meanwhile. My buddy NoXter once had those pads on his W1000, great comfort I must say. Actualy it was the only thing I liked about the W1000 at all besides its looks...
Quote:I have the mylar version, slightly modded to enhance the bass.
A friend of mine recently got a pair of NAD too, but his pair is also mylar driver/balance sounding. His stock pair currently sounds a bit light in bass compared to my modded pair.
Yup the mylars vary a bit from one to another in bass heavyness. But they are all more balanced sounding stock.
Obviously it means it requires less damping, its one or the other.
The eagle has landed. Your systematic was obviously correct, they have the round Y-splitter and have considerable bass, hello kaplon RP18!
First impression (besides the slightly muffy vintage smell) is that I don't miss that much SQ-wize. I am sold to that bone dry bass and its rich mids, and I am confident that some presence can be digged out quite easely. Technically, one can hear that this is really a different leage than all the other orthos I've tried until now, I expect it to end up somewhere close to my beloved MS Pro Ulti when everything is tuned in properly.
Reacts quite well on pad rolling and has enough ooomph for all sorts I tried, but I haven't found ideal pads in my inventory. Sounds okay with J$ pads and with those cheap Superlux ones, but I guess it deserves something "better".
Got a slight buzz from one side when it plays hefty deep bass, nothing serious, propably dirt...
Owing to suboptimal pad circumstances, I switched the EQ on to dig more presence out of the RP18. The preset turned out not to be as brutal as I had expected (by far), and so I sat down and just shuffled through my collection, Squarepusher, Bach, Monolake, Keith Jarrett, Monteverdi, Mogwai, Yello, David Sylvian, Amon Tobin....
I must say, the most enjoyable session I've had for years. I wouldn't say this thing can compete technically with all those 1K $ cans that get raved so much nowadays, but that manic sound weight and musicality is just outstanding. In respect of the latter, it even beats the DT531, which has been my (sadly dull) all time favorite in that respect. What is really special about it is its laidback and mellow character, even the most annoying stuff becomes much more listenable than with any other of my HPs, no fatigue at all. Musical bandwidth is okay, but not worldclass, it definetely suits better to fat and rhythmic stuff than to single violin partitas or kitten music IMO. And returning to the technical view, the gap between that NAD and my other orthos is really frightening, I'd locate it at least 2 classes above every other ortho I've tried or owned until now...![]()
Mine are recabled & damped. They have the same efficiency as my friends stock pair. They both are slightly more power hungry than LCD-2 though.
I don't understand what the fostex was upto. The mylar version has no lack of PRaT & is nigh-perfectly damped from the factory.
Did they just forget to place the diaphragm under tension on the Kapton ones.?![]()
Having NoXter's extra pair of hands available, I opened one system to try to get rid of the deep bass buzz, and it worked well. Now the bad news: The other side (which also has some ksssss issues) has been glued together by one former owner. No I've got to decide if I tolerate that buzz or if I rather try some more "robust" and dangerous methods to open that system.![]()
