rhythmdevils
Member of the Trade: rhythmdevils audio
- Feb 11, 2005
So Wualta, continuing the discussion of the backwave leaving the back of the enclosure and traveling around the outside of the headphone and through/around the pads to cancel out the bass or parts of the "frontwave"-- With the open back grado cups, when I cover the opening at the end of the cups with my hands and make a seal thus creating a completely closed headphone, all lower frequencies get completely wiped out, not just bass but midbass, and lower midrange as well. (I can't tell if it also slightly affects the higher frequencies, or if they are now just kind of naked without their lower frequency counterparts and this sound funny) If I even get my hand close to the cup's opening, these lower frequencies start to drop off. If the backwave cancels out the bass by leaving the back of the cups, then why would covering this open back diminish the bass? It seems like it must at least also work in another way. It must also travel through the diaphragm? Or interfere with the movement of the diaphragm?
Another interesting part of this is that with the T20v1 and grado cups, there are screw holes in the baffle that are now not being filled with screws, so they act as ports into the pad enclosure (frontwave). I currently have them plugged with tak, but removing them has an interesting affect of improving soundstage/air and removing bass. However, the loss of bass with even all three unplugged is not even close to the affect of covering the back of the cups. I would think that if the backwave was coming around the headphone, ports like this that lead directly from the outside to the "frontwave" would have a drastic effect, or at least more so than blocking the backwave.
